Best input DHT tube?
Old 10th June 2011, 06:51 AM   #1
neskor is offline neskor  Serbia
Default Best input DHT tube?
Any suggestion for DHT input tube for 10Y IT 300B amplifier?
Beside 26
Old 10th June 2011, 08:12 AM   #2
andyjevans is offline andyjevans  United Kingdom
This is really up my street. I've been experimenting with different DHT small tubes for 3 years in 300b SETs. In terms of input tubes I found I liked in approximately this order:
26 - my preferred option for tone and overall magic
10Y - capable of great clarity and dynamics, but I missed the 26
01A - very good, but not as magical as 26 or clear as 10Y
30sp (VT67) - surprisingly good, less microphonic than 30
46 - usually a driver tube, but very neutral with good tone
1G6G/GT - surprisingly good but very microphonic, so needs special mounting
I went with the 10Y for ages in different contexts but came back to the 26.
The implementation matters here. On the basis of listening tests I gave up resistor loads and solid state loads and went for a transformer/plate choke. 26 needs a high inductance load like 200H or more, and this is most easily found in a plate choke. I currently use a cheap solution - two Hammond 156C chokes of 150H, in series making 300H. It does the job fine, though clearly there will be more expensive and sophisticated options. I don't use a cathode bypass because I use filament bias, and the cathode resistor is just 10 ohms. I preferred filament bias to battery bias on the grid which would be my second best option. But I do use choke input plus a Rod Coleman boards for the filament - only works when it's super clean.
Like you I planned on using 10y as a driver, but when I started matching the 10Y up with interstages I surprisingly found that I preferred the tone quality of the 46. Usefully this sounded very good with the cheap but excellent Hammond 126C without cathode bypass, and also with the much more expensive Lundahl LL1692A. So I went with that. I was surprised not to be using the 10y because in AB listening tests in various other contexts it seemed to sound better than the 46. So it's really a case of getting the alchemy right.
Andy
Old 10th June 2011, 08:20 AM   #3
Thanx Andy!
I was waiting for your answer
Old 10th June 2011, 07:59 PM   #4
211hojbjerg is offline 211hojbjerg  Denmark
I'm using 8025a in my preamp, it is a great sounding DHT that tube can be used as driver as well for 300b. the tube has white filament like 10Y.
best
karsten
Old 10th June 2011, 08:20 PM   #5
it looks cool
Old 10th June 2011, 09:06 PM   #6
Vinylsavor is offline Vinylsavor  Germany
Vinylsavor's Avatar
Hi!
I always use step up input transformers with all DHT amps and stick to 2 stages. Of course this requires a preamp with low enough output impedance to drive the input transformer
Thomas
http://vinylsavor.blogspot.com/
Old 10th June 2011, 09:09 PM   #7
What kind of input transformer?
Old 10th June 2011, 09:15 PM   #8
Vinylsavor's Avatar
Hi!
Lundahl LL7903 works nicely for me
Thomas
Old 10th June 2011, 09:16 PM   #9
best
karsten
Holy Cow! Never seen that one. What a cool tube. What's your operating point - is it happy with around 250v on the plate?
I couldn't see any curves. Doesn't look too expensive.
Andy
Old 10th June 2011, 09:17 PM   #10
I have LL1636, can I use that?
Best input DHT tube?Hide this!Advertise here!
HQ-DHT (All tube DHT amli) 26-45-2A3 quanghao Tubes / Valves 44 20th January 2013 09:58 AM
For sale - several audiophile DHT tube amp/preamp projects (UK) andyjevans Swap Meet 9 16th December 2009 03:49 PM
F* amp VS Single Ended DHT tube amp xecluded Pass Labs 15 11th August 2009 07:59 PM
Input stage tube Steen Bentzen Tubes / Valves 2 6th October 2005 03:39 PM
input/driver tube brsanko Tubes / Valves 0 13th January 2004 07:18 AM
Copyright ©1999-2017 diyAudio
