| diyAudio Sponsor | ||
I have a 2 channel preamp with 2x 6sn7 per channel (4 total). Presumably push/pull?
Unfortunately 2 of the tubes (1 per channel) are horribly microphonic so I'm going to buy 2 new tubes to replace. I'll buy a fancy brand, so I can only afford 2 at a time For sake of the example, we'll assumre I've thrown out the bad ones, and the remaining tubes are "cheap" but the new ones will be "fancy" Which setup would be more sensible:
The essence of the question is really "is it a waste of a good tube to put it in the same channel (presumably push/pull) with a cheaper tube? |
#2 |
I would install them such that you have two identical channels in your amp.
#3 |
Did you try swapping the 2 tubes within each channel to verify that it's not just the first gain stage that's sensitive?
#4 | |
Did you mean though to just sap the positioning of the tubes within each separate channel? Eg the tubes are as follows ..left....right ..1.........2 ..3.........4 1 & 2 were both /microphonic, so I moved tube 2 to where tube 3 was. This gave me a noisy left ch and clean right ch You're suggesting swapping 1 & 3, and 2 & 4 ? What would I be looking out for if I did this? Thanks |
| Tamura HM-1 | fxsound | Tubes / Valves | 2 | 20th July 2009 07:42 AM |
| the audax hm 170c0 | Larin | Multi-Way | 16 | 27th June 2008 08:34 AM |
| 7868 tubes - replace with 6L6's? | PRNDL | Tubes / Valves | 6 | 29th November 2007 07:11 PM |
| Page generated in 0.07251 seconds (70.41% PHP - 29.59% MySQL) with 10 queries |
