| diyAudio Sponsor | ||
#2 |
#3 |
Do you have any model number on this . I take it your uncle is not here to help . I would vote that it was a cutting head amp more than a theater amp . This does have very good iron in it. It looks like your uncle did a fine job up dating it.
#4 |
This looks a lot like the Altec amps of the same time period - no surprise. Westrex was the UK arm of Altec / Western Electric.
Could be a British version of the Altec 1568
Take the Speaker Voltage Test! |
#5 |
I checked with my Uncle. He doesn't have the model number.
#6 |
No help for you but gosh that's purty.
mike - www.keepingsundayspecial.org |
#9 |
Pretty amp. I saw the quad of EL34, and hoped it was a stereo unit. Next I spotted the pair of GZ34, and was pleased it had enough rectification to properly handle all the output tubes. Finally I saw the schematic, and noticed the single output transformer that indicates it is a mono design. Pity, as I'm sure it has potential to be a good amp. It'll be difficult to find a matching amp to make a proper pair. Good luck!
#10 |
I "found" it in my inbox.
His comments: "I was donated a pair quite a few years ago that came from a PA hire company, so they were in appropriate condition. I scrapped them for the transformers (quite good quality), but the driver’s rubbish. Note especially the fiddle on the HT supply to cure motorboating."
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
| 60 watt troubles | rtill | Solid State | 41 | 14th April 2008 06:34 PM |
| 60 watt design... | rtill | Solid State | 11 | 10th January 2008 03:47 PM |
| 100 Watt Volksamp 60 ? | pyro2006 | Pass Labs | 8 | 12th December 2007 08:53 PM |
| my 60 watt amplifier | AAK | Solid State | 6 | 15th June 2005 12:59 PM |
| Page generated in 0.09739 seconds (75.09% PHP - 24.91% MySQL) with 11 queries |
