diyAudio Sponsor
Old 6th June 2011, 05:24 AM   #1
Dylan is offline Dylan  United States
Dylan's Avatar
Default SS Rectifers and Zero-Crossing Distortion, possible fix or idotic idea?
Please go easy, I'm still learning.
So far, I understand that a big reason for people preferring tubes over solid-state rectifiers has to do with zero-crossing noise.
As I understand it, the rectifier "drops out" below 0.7V or so, resulting in a sharp edge full of nasty Fourier components. Please correct me if this isn't quite right.
I had an idea on how one might correct this. Is it legitimate?
I decided to connect half of a 6AL5 vacuum diode in parallel with each rectifying diode in the belief that when the SS rectifier "dropped out," the 6AL5 would pick up the job of conducting. At about 0.7V, the current demand on the 6AL5 would be negligible. When the SS rectifier is conducting, the 6AL5 is effectively shorted and relieved from duty (which would kill it anyway).
I would imagine that the 6AL5 would "fill in" the parts that the rectifier is missing.
I can't tell if this makes any difference, but I'm curious if anyone else has thought about or tried this. Searches turned up nothing, and I lack the equipment to verify if this actually does anything.
The motivation behind doing this was that the same power transformer could be used, and the filament transformer only sees another 300mA.
Old 6th June 2011, 05:34 AM   #2
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
The problem with SS diodes is the charge stored in it that affects efficiency of high frequency SMPS rectifiers when the diode goes off. When rectifying 60 Hz this problem is imaginable.
The devil is not so terrible as his mathematical model!
Wavebourn: We Create Creativity!
Old 6th June 2011, 12:43 PM   #3
DF96 is offline DF96  England
Yes, charge storage is the problem. The SS diode will conduct briefly in the reverse direction until all the charge carriers are removed from the junction region, then it abruptly stops. This abrupt stop has high frequency Fourier components which may get into the audio circuitry. Paralleling with a thermionic diode won't make any difference - adding a thermionic diode in series might help because it reduces the current more gradually. The correct solution is either to use a different SS diode designed to reduce this problem, or add a parallel RC snubber to damp the spike.
Easier still, just keep the PSU well away from signal circuitry and reduce the area of any loops carrying charging pulses.
Old 6th June 2011, 01:52 PM   #4
Yvesm is offline Yvesm  France
Yvesm's Avatar
Don't forget that diodes start conducting only when the anode becomes more positive than the cathode.
That means only when the VAC (at anode side) exceeds the VDC (at cathode side) already stored in the "reservoir" capacitor.
More or less 0.7V is meaningless !
SS CCS and distortion Joshua_G Tubes / Valves 103 25th June 2010 08:21 PM
Looking for first SS amp idea, have PS whatsnext Solid State 16 4th August 2005 01:21 PM
Common cause of distortion in SS eeka chu Solid State 1 24th May 2005 10:54 PM
How to fix tweeter distortion problem paulspencer Multi-Way 8 26th July 2004 02:52 PM
Trying to fix a sub-amp with fuzzy distortion on the output Horn_aficionado Solid State 0 17th July 2004 03:38 AM
Page generated in 0.07426 seconds (73.12% PHP - 26.88% MySQL) with 10 queries
