| diyAudio Sponsor | ||
Hi there, thanks for reading.
I've got a "new" unused Stancor A-8053 Output Transformer that came with a lot of items from when a friend passed away. I think he may have intended it for replacing the OT in rebuilding a Dynaco MKIV, but I don't know for sure. Have any of you seen/heard these transformers in use? How would you describe their characteristics or quality? I have the Dynaco, which is empty save for iron. My range of interest for amp building is wide, so any info you could give in helping me use this for the best application is appreciated. Thanks! Jeff |
#2 |
I have the specs on the 8053 as follows...
Push pull with the primary 5k ohm plate to plate load res at 150ma Secondary has taps for 8 and 16 ohms 50 max audio It could be used many ways... Push pull 6550 or kt88 PP 6L6 PPP 6v6 PPP EL84 PP 300B PP 2A3 PP 6a3 The list could go on and on with various conbinations, they are nice.. I hope this helps, BTW google bunker of doom transformers for the stancor 1961 pdf and it will be listed on page 13a. If you don't like them just let me know ... They should be a good starting point for a very nice amp build. Have a great day, Michael |
#3 |
So, I'm still pretty green - What's PPP?
#4 |
Hey Jeff,
It's all good, PPP is push pull parallel meaning two tubes on each side of the primary windings. In order for it to work with 2.5k per side (5k plate to plate) on the transformer primary, use two tubes on each side that have a load resistance of 5k because when paralleled it halves their virtual load resistance to 2.5k. Also take into account the max ma of anode disapation for the four tubes combined for the transformer rating of 150ma. I hope this helps, I tried to explain best I could been at this just about 6yrs. Have a great day Michael ps. If you need more help don't hesitate, but I am not an expert by far here just proficient. |
#5 |
^you can also connect your 8ohm speakers to the 16ohm tap to make the primary a 2.5k load...
http://www.electronicslab.ph/forum/i...?topic=32688.0 |
#6 |
Thank's Tony,
I forgot to mention that he could halve the impedence that way. That could bring the Load resistance down to 1.25k per side effective way to run push-pull parallel of other combinations as long as the 150ma rating of the OPT is observed. any way just my 2 cents. Last edited by mltube; 6th June 2011 at 12:20 AM. |
| Stancor Transformer Data Sheet Needed | Trout | Tubes / Valves | 2 | 30th December 2008 10:42 PM |
| Output transformer wanted | Johan Potgieter | Tubes / Valves | 5 | 18th November 2008 09:55 PM |
| Stancor RT-204 transformer for chipmap power supply? | lapoltba | Chip Amps | 4 | 29th January 2007 04:03 AM |
| 2A3 SET Output Transformer opinions/recommendations | wwflyball | Tubes / Valves | 24 | 3rd January 2005 06:28 AM |
| Page generated in 0.08429 seconds (75.89% PHP - 24.11% MySQL) with 10 queries |
