Is WE310A > 45 > 300B PP possible? - diyAudio
Old 5th June 2011, 02:39 AM   #1
VR2ZXP is offline VR2ZXP  Hong Kong
Default Is WE310A > 45 > 300B PP possible?
Hello everybody,
May I have your help?
I want to build a 300B push pull power amplifier.
WE310A > 45 single end > interstage transformer > 300B PP > Tamura F2021.
Q1) Which value of interstage transformer and the bias point are suitable? I suppose the Tamura B500X series.
Q2) Will the gain of this circuit too high?
Thank you so much!!
Fai.
Old 8th June 2011, 12:32 AM   #2
brady is offline brady  Philippines
Hi VR. Discussing the operating point/s of a PP 300B into a specific load (the F2021) will take some time. I would suggest you take a look at the tube curve and define your operating point from there. You can later fine tune according to your speakers/ears
The total gain depends on voltages and current in all three stages. Since these are all low gain tubes, I don't think there'd be too much gain. Just distribute them across the stages well.
The 45 would have more than enough current and voltage to swing the 300B. cheers
FOR REGA Turntable>>> The heavy weight + Vta adjuster+ceramic ball prooptiki Swap Meet 1 22nd May 2010 06:57 PM
Multi-DAC: Lynx AES16 -> DIR9001/SRC4392 (-> SRC4192) -> PCM1794A novec Digital Line Level 11 11th May 2010 12:57 PM
> Audio <> music <> quick <> synergy <> angst>? rick57 Everything Else 0 4th May 2007 05:03 PM
&gt;&gt;&gt; cheap 50,000uF 60V capacitors here &gt;&gt;&gt; Lubomir Swap Meet 0 1st February 2007 04:36 PM
12ax7 > 6sn7 > 300b TunaFish Tubes / Valves 4 21st June 2004 06:43 PM
Copyright 1999-2017 diyAudio
