NTC Thermistor As Soft Start For Tubes
Old 12th February 2013, 09:45 PM   #61
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
I am not of a different opinion, I just did not mean _slow_ charge of "electrolytes". Slow charge and time delay are completely different things. I use resistor in primary exactly for "slow charge of electrolytics", limiting inrush current. After electrolytics had been charged up to 70% of the voltage the relay shorts the resistor and stays on until power is not removed and electrolytics discharged.
Nothing in the universe is perfect. The ideal things are the ones that are most optimal. Optimization criteria, what matters. When I hear "No Compromise Design", I want to take a sledgehammer and test how impact-proof it is.
Old 13th February 2013, 03:30 PM   #62
Leakstereo20 is offline Leakstereo20  Denmark
I have to sharpen my written English.....the concept was:
By the delay of the +B voltage the in-rush current limiter was implied.......
During the delay-period the idea was to have "a slow charge of the capacitors" and that the heaters during the same delay had reached max. before the full +B voltage was connected.
Old 15th March 2013, 08:29 PM   #63
Wavebourn's Avatar
I received boards today, smallest one is for slow start/surge charge limiter. Bigger one is for rectivier. Originally it will rectify 400+400V. The biggest one contains rectifiers for negative bias and filament of preamp tubes, also voltage stabilizers for -72V (bias), +12.6V (filaments), +270V (screen grids) and +400V (preamp and driver).
Also, the longest board will have on it couple of 20 uF film caps, shunt for 800V B+ power. It contains star ground and all output voltage pads.
Old 15th March 2013, 08:36 PM   #64
iko is offline iko  Canada
iko's Avatar
Shunt for 800V B+? What is that?
Old 15th March 2013, 11:35 PM   #65
Wavebourn's Avatar
It shunts 800V B+ on AC by 10 uF film cap, directly to the star ground. Such way output tubes are powered as if from 10 uF film caps (20 uF/2), but rectified AC is actually smoothed by 470uF/2 electrolytic cap + 10uF film.
All power supplies at their outputs are interconnected at the star ground. Such "zero volt reference" eliminated the "sonic difference" between rectifiers and power cables.
Old 18th January 2015, 12:16 AM   #66
MelB is offline MelB  Canada
In bypassing your soft start resistor or NTC do you guys see any advantage one way or the other between a mechanical relay or a solid state relay like a CPC1998 for example.
I see the solid state relays take much less power to stay "ON".
How about durability? Any experience?
NTC Thermistor As Soft Start For TubesHide this!Advertise here!
how to select an ntc thermistor? jarthel Parts 8 13th March 2016 09:35 AM
if an NTC thermistor is rated... jarthel Parts 2 21st May 2007 12:06 AM
help with ntc thermistor jarthel Parts 4 1st October 2006 04:57 PM
Thermistor vs Soft Start argofanatic Parts 12 22nd September 2005 12:46 PM
