#41 |
#42 | |
In the past I had considered putting a diode on the input side of the inductor on a CLC filter, in the hopes it would prevent oscillation of current thru the inductor between the caps on either side of it back and forth and back and forth... Sorry to ask such a basic question (it's been 45 years in software since my minimal electronics training), but how do I calculate the additional voltage drop across the diode in the forward direction and would it be significant? Can somebody recommend a hefty diode for the job (500 V, 500uF cap, 1.3H inductor, 2500uF cap on a 180-watt tube amp)? Otherwise I was considering adding two other ways of damping the low-frequency oscillation: a resistor in parallel with the inductor (ruining its sharp q) and a resistor in series with a cap (across the output) to burn up & slow down the voltage changes (but it requires a big cap to damp optimally). |
#43 | |
![]() The relay is powered from output of this regulator.
If I disappear suddenly, that means I finally created a time machine and pushed wrong button that brought me to Stalin's Russia. In any experiment any result is the result. Even if it is negative. |
#44 |
For a fixed bias amp, I power a protection relay coil from the raw filtered bias supply, to provide a mechanism for bias voltage failure. The NO relay contact is used to connect a low resistance (or just bypass link) across a soft-start resistor in series with the secondary HT winding.
Additonal functions can be integrated by using a FET to switch the relay coil, and use a long RC time constant FET gate drive signal from the bias voltage to give say a 20-30 second delay on relay energisation, which can alleviate B+ voltage overshoot (especially if ss diodes are used and output stage bias current is needed to keep B+ lower than filter cap voltage ratings or tube anode/screen ratings). The above focusses on the long delay needed for output tube heaters to allow bias current to rise at the same time as B+ rises. I'm happy to use a suitably chosen NTC to alleviate transformer in-rush, and then when the protection relay kicks in to also help alleviate B+ capacitor in-rush or diode stress if they are of concern. |
#45 | |
Don't size resistor so many ohms the real fuse on hot side never blows. Don't make relay controller so dumb it can't or won't close relay when there's a short (and fire) that needs the fuse blown. I'm just sayin' because I saw this recently in a SMPS, and it irritated me. Some dweeb is surely gonna put out that fire with ... use imagination ... Damn engineer wouldn't spend a few bucks to replace with an NTC that wouldn't have caught fire, and could have blown the main fuse. It really should have been on the hot side, but an NTC would at least made his junk a little bit safer without redesigning the whole board... No, he put that relay so it "wouldn't need" an NTC. Yeah, what...? Me no engineer - me too dumb - thinking not job - shut up and test. Last edited by kenpeter; 9th February 2013 at 11:31 PM. |
#46 |
I use a CL80 on the 110 side of the transformer for inrush current control for the first cap. It allows for a smaller fuse to be used. Then C-DIODE-C-L-C. The diode bridge feeds the first cap, Now I place a damper diode as a pass device to another cap that feeds the subsequent filter and B+ bias string. I've done variants of this on many amps and also used it on a slow start for my RIAA and Preamp ( 12AL5 in this application).
The damper diode is the tube in the middle behind the 6550's.
SO many tubes, SO little time!!! |
#47 |
#48 |
Wavebourn, you have made several tubeamplifiers for PA according to your site.
Soft-start for longer lifetime of capacitors and tubes is one issue, "overload" is another. For home hifi it would be nice if the amplifier shuts down (or partially down) by overload ....may be depending on the amount of mA measured across the cathode resistor? ...like a DC sensor for solid state amplifiers. Do you have any suggestions to a simple tubeamp overload protection, which does not affect the sound? ....in several tube designs with good reputation old tubes "runs" with bias and leaves us a red glowing plate and a tube melt down. Can we do anything to avoid this? |
#49 |
Rick...
seeing your pictures,- have you looked at overvoltage suppressors? For serious and sensitive installations, it is quite common to install a 'coarse' suppressor setup at the power intake, and another 'fine' suppressor in the relevant consumer line circuit ( going to your ampliifers and stuff) ....
While the Lie leapt from Bagdad to Constantinopel, the Truth was still looking for it's sandals! |
#50 | |
tube heaters when cold emits no electrons, so leaving them connected to circuit under full voltage cannot make them break. Just piece of metals in vacuum In my opinion, leaving everything normally connected is better than heating them up and later turning anode supply on. Risk of current spike through tubes Vacuum rectif. has softstart "built-in", but the voltage sag is not nice. |
| if an NTC thermistor is rated... | jarthel | Parts | 2 | 21st May 2007 12:06 AM |
| how to select an ntc thermistor? | jarthel | Parts | 7 | 2nd April 2007 10:00 PM |
| help with ntc thermistor | jarthel | Parts | 4 | 1st October 2006 04:57 PM |
| Thermistor vs Soft Start | argofanatic | Parts | 12 | 22nd September 2005 12:46 PM |
