diyAudio Sponsor
Old 3rd June 2011, 01:04 PM   #1
jmillerdoc's Avatar
Default Basic schematic for Dodd Audio tube buffer?
Does the basic schematic for the Dodd Audio battery powered tube buffer exist anywhere? I am curious how the tube is run on the 12v rail. Would like to see the basic tube circuit used for this tube.
Thanks,
Jeff
Old 3rd June 2011, 02:45 PM   #2
mastodon's Avatar
Sounds like a relatively straightforward cathode follower with fancy components. HV can be made out of 12V DC using an inverter/smps and some filtering. I don't think it runs the plates on 12V.
DIY Dodd Audio Buffer Kit jtwrace Analog Line Level 11 3rd August 2011 12:37 AM
schematic yaqin cd1 tube buffer asuservice Tubes / Valves 3 28th November 2009 11:36 AM
Need Schematic for 12 Volt Tube Buffer becki200 Tubes / Valves 3 17th January 2009 08:42 PM
LM 3886+tube buffer.....schematic? moolder Chip Amps 4 2nd February 2005 03:16 PM
Dodd Audio Dodd Amp Mach_Y Tubes / Valves 0 27th April 2003 03:43 AM
Page generated in 0.06979 seconds (71.55% PHP - 28.45% MySQL) with 10 queries
