diyAudio Sponsor
Old 3rd June 2011, 02:34 AM   #1
TheGimp is offline TheGimp  United States
TheGimp's Avatar
Default EL844
I thought I'd post a couple pix on this new offering. When I first read about it, I thought they might be using a modified 6P1P but after looking at one I would say it is a complete new design.
I don't have time to test it right now, but it is rather interesting.
One side is completely open (to aid in grid alignment during assembly?)
It is a true pentode with grid, G2 and suppression grid, no beam forming plates.
The plate looks elliptical to me with no barkhausen (sp) suppressor.
Old 3rd June 2011, 10:01 AM   #2
mastodon's Avatar
Or to improve the possibilities for convection cooling of g2? Which is unlikely as I come to think of it, since this is apparently intended as a lower-powered version of the EL84 for guitar amp lovers who fancy a creamy tone without damaging their ears.
Old 3rd June 2011, 10:41 AM   #3
Ty_Bower's Avatar
I'd certainly hope not! In a vacuum, there should be no possibility for convective cooling. The primary mechanism of cooling should be radiative, with some amount of conductive cooling occurring through the pins.
Old 3rd June 2011, 11:21 AM   #4
DF96 is offline DF96  England
As it is essentially 2/3rds of an EL84, maybe the simplest way to make it was to take an EL84 design and remove 1/3rd of the anode?
Old 3rd June 2011, 11:30 AM   #5
mastodon's Avatar
Uhm. Good point...
Old 3rd June 2011, 11:51 AM   #6
Gilgy is offline Gilgy  United Kingdom
Conspiracy theory about them here ...
EL844 anyone seen these?
Old 3rd June 2011, 04:04 PM   #7
smoking-amp's Avatar
Are they 33% cheaper too? Usually the tube makers kept making bigger versions because the amp designers smoked them to the limit.
Ohms Law V = I R
Old 3rd June 2011, 05:19 PM   #8
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
Metals are expensive today, so less metal on plate looks quite economic.
The devil is not so terrible as his mathematical model!
Wavebourn: We Create Creativity!
Old 3rd June 2011, 05:31 PM   #9
But why did they cut the side off, rather than just making the whole thing shorter?
Old 3rd June 2011, 05:37 PM   #10
Wavebourn's Avatar
Shorter means less linear, since less of uniform field in respect to non-uniform fields on edjes. I personally would prefer longer tubes. My dream is to get GU-50 tubes longer 50%, with phallic symbol bulbs. It would be the bestseller.
Page generated in 0.09292 seconds (79.44% PHP - 20.56% MySQL) with 10 queries
