diyAudio Sponsor
Old 2nd June 2011, 08:09 PM   #1
Default Help 7189A Tubes!
Hi guys, I'm looking to purchase 2 matched pairs of NOS/GE 7189A tubes-(not 7189) to reurrect my old Pioneer SM83 amp. I'v tried most of the valve stores on the net with no luck. I'm from South Africa, can anyone help?
Old 2nd June 2011, 08:53 PM   #2
WildOne's Avatar
https://www.tubeworld.com/7189.htm
Old 2nd June 2011, 09:09 PM   #3
already checked out their site. They don't have any matched pairs except for a pair of Toshibas for $179. A bit steep for me. From what I've seen a matched pair of GE's & NOS normally go for around $100-$130. Thanks WildOne.
Old 2nd June 2011, 10:03 PM   #4
kevinkr's Avatar
Try the Russian made 6P14P-EV or ER - pretty close to equivalent, might need to make some adjustment to the bias.. (These are readily available on eBay) I prefer the ER, but it may be getting rare at this point. They're a good deal less expensive than the 7189 or 7189A and I've found usually work well in applications calling for either.
www.kta-hifi.net
Old 2nd June 2011, 11:24 PM   #5
tubelab.com's Avatar
If the amp runs the screen grids at 330 volts or less, use JJ EL84's. I run them in Simple P-P's at 330 volts screen, 440 volts plate, 12+ watts dissipation and extract up to 30 watts from a pair.
Too much power is almost enough! Turn it up till it explodes - then back up just a little.
Old 3rd June 2011, 02:13 AM   #6
Banditt,
The 7189A has pretty much gone the way of the Dodo. AAMOF, NOS 7189s (no "A") are quite scarce. Kevin gave you good advice. The Russian 6П14П-ЕВ (6p14p-ev), AKA EL84M, is a true 7189 equivalent, with decent sonics and a favorable price. Rework the Pioneer amp O/P tube sockets to 7189 spec's and slightly lower the "idle" current.
Eli D.
Old 3rd June 2011, 07:16 PM   #7
Seriously considering taking Kevin's advice, besides I don't have much of a choice.
Thanks for the great advice guys, really appreciate it.
EL-84 substitute for 7189A zacknorton Tubes / Valves 8 21st September 2011 06:08 PM
Runaway tubes or tubes drawing excess current--baffling trombone Tubes / Valves 13 16th April 2011 11:27 AM
MC3500 with 807 tubes and modern driver tubes tryonziess Tubes / Valves 11 23rd February 2011 07:01 PM
FS: 2 Tung-sol 45 tubes, 2 Westinghouse 5u4gb tubes athos56 Swap Meet 0 3rd August 2010 11:18 PM
7189/7189A Problem Victoria Tubes / Valves 6 22nd January 2007 03:08 AM
Page generated in 0.09543 seconds (75.88% PHP - 24.12% MySQL) with 10 queries
