diyAudio Sponsor
Old 30th May 2011, 02:30 PM   #1
Audio Junkie
Zero Cool's Avatar
Default Adding Bal output to Akido
I have built a 6SN7 akido pre-amp and it works very well and I am pleased with the sound but I want to add balanced outputs. I was thinking of just using an opamp to invert the unbalanced output. while not true balanced, it would provide differential drive. But is there a better way? I would like something that is as colorless as possible. expensive transformers are not an option.
can a couple of opamps be used in a unity gain configuration and be colorless??
It's not about what you can BUY...It's about what you can BUILD!
WTB Akido boards. Tony D. Swap Meet 0 6th December 2009 10:32 PM
Adding secondary of output transformer into cathodes of output stage ? Eico ST-70 freddymac406 Tubes / Valves 3 21st April 2007 06:15 PM
upgrading to bal. output trannys redrabbit Solid State 7 1st January 2006 08:42 AM
Adding a sub output to a SI jarros Class D 4 21st April 2005 08:22 PM
Bal-Unbal-Bal Cable Wiring richie00boy Everything Else 3 3rd February 2005 11:08 AM
Page generated in 0.05596 seconds (65.03% PHP - 34.97% MySQL) with 10 queries
