| diyAudio Sponsor | ||
Hi all,
I recenly built a simple tube based pre-amp with an input impedance of about 470K. I was wondering if higher is always better when it comes to input impedance or maybe not because of higher johnson noise from the resistor from input to ground ? Maybe I should change my input resistor from 470K to 47K. What do you think? Regards, Ronald |
#2 | |
Cheers Ian
Ian |
| opamp output - how to make its impedance higher? | peskywinnets | Solid State | 5 | 27th May 2011 09:18 PM |
| WTB: 10,000uf or higher 71V or higher caps, max 30mmD | KevinLee | Swap Meet | 1 | 10th December 2009 12:39 AM |
| How to design input stage with specific input impedance/pot value | mahleriana | Tubes / Valves | 0 | 16th November 2009 09:37 PM |
| Higher impedance = cleaner volume? | JonnySwitchblade | Multi-Way | 8 | 10th July 2007 06:58 PM |
| Page generated in 0.06112 seconds (80.15% PHP - 19.85% MySQL) with 10 queries |
