| diyAudio Sponsor | ||
Hi all.
I recently build a simple cathode follower (B+ = 200V) to replace the solid state pre-amp (I did not need the extra gain) in my integrated stereo amplifier. The reson I choose a tube (6H30P-DR) is because in my opinion it sounds better. This is debatable of course, but please not in this thread ;-) There is a 1M resistor from grid to ground and thus the input does not have a DC component. I still use a capacitor on the input though cause I am afraid to blow up my expensive sources when something goes wrong (as in high voltage DC at the input). My question is, what is the risk involved with DC coupling the input here? Or can I safely omit the input capacitor ? Regards, Ronald |
#2 |
The risk is not so much blowing up the input equipment, as putting a dc voltage (coming from the input equipment) on the cathode follower's grid, resulting in bias problems in the tube. If you're absolutely 100% sure that there is never going to be a dc voltage on the input, you could remove the input cap. But I'd leave it in place personally.
#4 | |
So I suppose I it will be safe to ommit the input cap then? No chance of getting DC at the input when the tube gets defective? Regards, Ronald |
#5 |
#6 | |
Keep in mind that most sources will have an output cap of their own.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#7 |
#8 | |
But if I understand correctly, risk is near zero and I can safely ommit the input caps, which I do prefer because of the small gain in transparancy of the sound. Ronald. |
#9 |
If you have a high voltage on the cathode, how can you have a 1M resistor to ground at the grid? That makes no sense. Perhaps you should post a schematic.
#10 |
With the grid at ground level a 6H30 should have ca 6V to ground. Unfortunately this leads to higher distortion as the cathoderesistor will have quite a small value. Better to use a negative voltage and a CCS.
Brgds Lars |
| Balanced input all DC coupled RIAA preamp | FdW | Analogue Source | 82 | 5th February 2012 06:22 PM |
| D-amp for DC coupled applications | lalalala | Class D | 8 | 20th December 2010 09:23 PM |
| A DC coupled headphones amp | Gluca | Tubes / Valves | 0 | 27th January 2010 01:08 AM |
| Help designing Class-A, tube, transformer coupled, studio grade pre-amp | gibsonripper | Tubes / Valves | 8 | 14th December 2007 09:02 PM |
| A safe (?) DC coupled amp | Fuling | Tubes / Valves | 4 | 8th July 2004 06:51 PM |
| Page generated in 0.10434 seconds (78.33% PHP - 21.67% MySQL) with 11 queries |
