| diyAudio Sponsor | ||
Hey, so I've had a Yaqin VK-2100 for over a year now and a few months ago I started getting this wierd intermittent static from one channel. It doesn't matter what volume it is set to, doesn't matter which aux input i have selected, I have trouble shot and made sure it is not the one speaker. It seems to get more constant and more annoying as the amp warms up. I have also moved around the tubes to make sure it's not a bad tube. Any thoughts?
Thanks in advance for any advice. |
#2 |
You could try pulling the tubes from the affected channel before switching the amp on, if the noise is still there then it indicates a problem in the solid state output circuit rather than the tubes.
#3 |
Had the same problem, only moderately fixed. - Switch the cheap pre-amp tubes around to different sockets. Mine were crappy from the start and replaced with JJ's. -Find the massive VK-2100 thread here and other boards on how to adjust the bias and output levels. I still, at times, get the same "static noise" problem you have usually at power up. Mine slowly goes away as it warms up and is in use.
#4 |
***Still need a separate, specific forum just for Yaqin (Yaoin) audio tube products...
#5 |
SO, I got new tubes and they sounds great, but now I have one channel that is clearly louder than the other. I can adjust the balance on my computer and the sound is great when I set it so that the balance is further to the right channel. But it seems I shouldn't have to do this right? I should be able to have the balance set to default and not have one side be louder than the other. I have tried all the troubleshooting I can think of: switched tubes, switched speakers, switched cables, switched input source, etc. I have narrowed it down to the amp, but what in the amp could be the issue?
#6 |
anyone?
| Yaqin VK-2100 mods | Rockmore | Tubes / Valves | 61 | 23rd May 2012 11:53 PM |
| Yaqin VK-2100 hybrid running 4 ohm speakers | Rockmore | Tubes / Valves | 2 | 9th April 2012 01:55 PM |
| Ideas on weak left channel with static? | matt82609 | Tubelab | 4 | 13th June 2010 07:28 PM |
| Yaqin MC-100b channel imbalance | al3700 | Tubes / Valves | 1 | 22nd October 2009 06:35 PM |
| NEWBIE needs help-static in one channel of preamp | jj69 | Tubes / Valves | 5 | 27th June 2004 10:49 PM |
| Page generated in 0.08453 seconds (73.85% PHP - 26.15% MySQL) with 10 queries |
