Diodes to tube
Diodes to tube
Old 28th January 2013, 09:20 PM   #21
Miles Prower is offline Miles Prower  United States
Miles Prower's Avatar
Originally Posted by oldschooltube View Post
Hi everyone, I'm a newbie here @ DIY so please bear with me.
My question is this: I have recently built the 16LS kit from S-5 Electronics and I would like to switch the bridge rectifier chip for the B+ with a rectifier tube (5u4GB maybe?). Has anyone done this or does anyone have a good schematic to do this? Could I use a separate trans. for the 5U4's heater?
Why would you want to do that?
It's something I definitely wouldn't recommend. The forward voltage of Si diodes is typically 0.7V. Have a look at the 5U4GB spec sheet and the plate characteristic. The forward voltage is a good deal higher, and can approach 100V or more. You'd lose a helluvalot of voltage by replacing the Si diodes.
For one project, I used a 5U4GB precisely because the PTX I had overvolted badly with Si diodes: 458Vdc (unloaded) as opposed to the design nominal DC rail of 350Vdc. This vintage, NIB PTX (a Stancor: 650Vct/150mA; 5.0V/3A; 6.3Vct/5A) was obviously designed to use this type in a 350V power supply. The current rating was right, but I needed to lose 100V, which was the forward voltage picked off the plate characteristic.
There are no foxes in atheistholes
www.dolphin-hsl.com
Old 28th January 2013, 09:26 PM   #22
scott17 is offline scott17
Maybe I should have started a new thread. This thread is pretty old. I thought since my question (post#19) was similar in regard I would just post here.
Thanks,
Scott
Old 29th January 2013, 02:59 AM   #23
I did find, after many different search term combinations, find a reference to this type of connection. It stated to use a CR filter for each of the 2 cathodes, then tie the far end of the two resistors together to combine the two rectifier outputs. The resistors acts to balance the load between the two rectifiers. As an educated guess for this circuit, a 10uF cap followed by a 50R resistor may work. The same reference also stated that paralleling the transformer secondaries, as long as they are matched, and using just 2 diodes also works.
Originally Posted by scott17 View Post
I did not want to start a new thread just for this, so,
I have a PT with two 300V secondaries and want to use two 6BY5GA in parallel.
Can I connect them like this, or is it better or just as good to parallel the two 300V secondaries and then parallel the 6BY5GAs and use only 2 diodes?
The series limiting resistors are not shown on the drawing.
Thanks.
Scott
Diodes to tubeHide this!Advertise here!
Correct Path: Diodes Or Rectifier Tube? JimOfOakCreek Tubes / Valves 74 31st December 2010 11:01 PM
diodes changsecho Solid State 1 31st May 2008 04:32 PM
Tube rectifier to Solid state Diodes exchange finwbu Tubes / Valves 2 20th July 2007 05:41 AM
Old Diodes betweenpie Tubes / Valves 2 3rd June 2007 04:06 PM
what to look for - diodes Raj1 Parts 1 18th September 2003 01:44 AM
