PSUD modelling of a filament supply - Page 7 - diyAudio
Old 23rd August 2003, 03:19 AM   #61
OK, I now have most of the parts for the filament supplies. Still waiting on the transformers and I need to pick up some of the resistors and pots, but I can assemble most of the circuit now.
I have a question about PCBs/prototyping boards. The local Radio Shack didn't have any "peg boards", so I bought a pair of boards that have solder traces on them. I've used these before, and the traces lift if you keep an iron on them for 2 seconds (i.e. they're really flimsy and annoying), so I don't think I should trust them with 2.5A of current, right? I was planning on using them as peg-boards, i.e. use hookup wire for component-to-component connections and use the board just to mount stuff, no currents flowing through the board's traces.
Does anyone see any issues with that? Or is that an unsafe plan, and I should go get real peg-board, or proto boards capable of handling the currents that will be going through them? Or anything else? For others who have built high-current circuits with discrete diodes and regulators (i.e., lots of chips), how have you mounted them?
Thanks,
Saurav
Old 23rd August 2003, 07:13 AM   #62
EC8010 is offline EC8010  United Kingdom
diyAudio Moderator Emeritus
EC8010's Avatar
If you are lifting traces it is because your iron is too hot. Either you have a temperature controlled iron set too high, or you have a crude iron that belongs in the bin before it destroys any more parts.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 23rd August 2003, 03:48 PM   #63
Well, that was back when I was using my cheap Radio Shack iron. I now have a Hakko temp-controlled iron. It's set to 750F, and that's what I've been using it at. Is that too high? Maybe it's OK for resistors and capacitors, but I should lower it when working with the diodes and regulators?
And do you think a proto-PCB will be able to handle 2.5A through its traces? Here's the part: http://www.radioshack.com/product.as...5Fid=276%2D170
Old 23rd August 2003, 04:40 PM   #64
EC8010's Avatar
Default El hacko!
Gosh, yes, 750F (400C) is too hot, 315C (600F) is more suitable. Love the name of the iron!
2.5A is probably too much for a PCB trace unless it is very wide. Others can probably give better guidance.
Old 23rd August 2003, 05:19 PM   #65
Thanks. These traces are certainly not wide. The boards look like they were meant to build 555 timer blinking light circuits on.
K-502 Filament supply (or K-12M) jmillerdoc Tubes / Valves 6 18th November 2009 12:59 AM
Modelling stereo PSU in PSUD ... lordvader Tubes / Valves 1 29th September 2008 05:58 PM
Modelling a DC filament supply in PSU Designer II G Tubes / Valves 3 7th February 2008 10:59 AM
Parallel vs. series filament supply - or another filament idea engels Tubes / Valves 11 13th May 2007 01:06 PM
When using a DC filament supply on a DHT... Saurav Tubes / Valves 31 18th September 2003 05:03 AM
Copyright 1999-2017 diyAudio
