| diyAudio Sponsor | ||
tt/cd/tuner to modded dyna pas3 to diy kt88pp mono block amps all stacked on glass shelving - power amps hum even if cables are disconnected (same level on open or shorted amp input). they are dead quiet on work bench w/wo pas3 connected. if cd player is connected directly they are MUCH quieter. changing cables or adding ground interconnects didn't help. All components work well when placed in my other system = ??
#2 |
Are your heaters lifted above ground? Is your chassis earth grounded? Is your audio ground connected directly to chassis, or does it go through a ground loop breaker?
#3 |
nightanole - thank you very much for suggestions - units are the peter milett diy universal pp kt88 - heater ct to ground, chassis is earth grounded, audio to chassis - checking to see if I have open to ground - wouldn't be the first oversight I've committed - wmp
#4 |
heater ct to ground is your problem. Im surprised it didnt arc with that much voltage between heater and plate.
lift the ct of the heaters above ground using the boards built in r23 and r24. You should be good then. |
#5 |
uniamp green original board doesn't have the 10k r24 of the uniamp2 red board - how/where can I add the 10k lift resistor? Also, while I am asking - I see the version 2 deletes c11 for choke input. I added dropping resistors on b+ to get hv down to reasonable. should I delete c11 on version 1 as well?
| does some know how to build a 60hz hum Eliminator which stops the 60 hz hum?? | prorms | Solid State | 21 | 13th August 2011 07:26 PM |
| 50/60Hz Hum - Your Expert Opinion Please | LinuksGuru | Tubes / Valves | 14 | 27th February 2009 10:14 PM |
| Phase Linear 700 Series II - 60Hz Hum | craigstrat | Solid State | 6 | 28th September 2008 02:45 AM |
| 60Hz hum with Dayton 70W plate amp | diydave | Solid State | 1 | 15th July 2008 07:28 PM |
| Help - Getting loud 60hz hum when testing my passive high-level crossover | owdi | Solid State | 3 | 24th December 2006 08:14 PM |
| Page generated in 0.07416 seconds (69.50% PHP - 30.50% MySQL) with 10 queries |
