| diyAudio Sponsor | ||
Hello
At Virtually The National Valve Museum I found the following opinion: " Most 6C5s were of the metal-envelope type whereas most 6J5s were 'GT/G' and therefore suitable for a wider range of applications. " Is there someone who can explain that Regards Benny |
#2 |
First 6J5'swere metal, but the metal envelope process was expensive....
Cheaper to make 'em in glass.... In some applications, the envelope built up a charge and needed grounding, otherwise it could cause strange effects.... |
#3 |
Very true... The 1st tube amp I built used metal 6L6's and I didn't ground pin 1. Besides being very hot, the metal 6L6's would give a nasty shock if I accidentally touched them. I 1st thought that was the tube's way of warning me that they would burn me if I touched them!
#4 |
It's also worth mentionng that when introduced in the mid '30's, the 6C5 and 6J5 were commonly used in RF applications. The metal envelope provided shielding without the use of a separate external tube shield. In the absence of proper shielding, stray capacitance can cause frequency shifts in glass tubes used at RF frequencies - not a good thing for steady reception.
Frank Jones' "Radio Handbook for 1936" has several receiver circuits that feature these tubes as RF amplifiers and oscillators. Last edited by Mr. Zenith; 27th May 2011 at 05:02 PM. |
#5 | |
Even then (1968) I determined that you CAN make a metal 6L6 tube glow red. Someone told me that I couldn't, so.... It takes a few Eico power supplies wired together and the paint smells bad as it peels off the can. Hint....put about 800 volts on the can with respect to the plate which is already glowing from the 400 volts applied without negative bias.
Too much power is almost enough! Turn it up till it explodes - then back up just a little. |
#6 | |
The devil is not so terrible as his mathematical model! Wavebourn: We Create Creativity! |
#7 | |
We had hundreds of new surplus RCA metal 6L6's in our high school electronics class. They all came from Homestead Air Force base surplus. I personally blew up several dozen. I tried water cooling to increase power and saw that old Stromberg amp (also Air Force scrap) crank out over 200 watts from 4 metal 6L6's and several Eico power supplies in series parallel. I don't know how much the water helped, but it kept the smell of burning paint below the teachers threshold for screaming at us. The first picture shows a 6L6GC dissipating 44 watts. The 6L6GC is rated for 25 to 30 watts depending on whose data you believe. The metal 6L6 is rated for 19 watts. The second picture shows a 6BQ6GA at 60 watts it didn't last too long.
#8 | |
#9 |
Tubelab you definately live by the rule "Smoke em if you got em"
The Myth: A hand full of Tubes, Caps, Resistors and Iron and you have an Amp. The Reality: You have self induced Dementia. Newbie. |
| Schematic explanation | johnnystulic2004 | Solid State | 1 | 20th October 2010 04:11 PM |
| Circuit explanation sites | freakyone | Everything Else | 5 | 15th November 2007 10:01 AM |
| Explanation for this problem? | Rob11966 | Tubes / Valves | 4 | 22nd September 2007 04:39 AM |
| Explanation of Self Oscillating Class D | Genomerics | Class D | 19 | 29th October 2006 04:31 AM |
| Class D Multiphase explanation | rtarbell | Class D | 2 | 9th January 2006 06:12 PM |
| Page generated in 0.10886 seconds (79.69% PHP - 20.31% MySQL) with 11 queries |
