diyAudio Sponsor
Old 27th May 2011, 05:53 AM   #1
studeb is offline studeb  United States
studeb's Avatar
Default Dynaco FM1 stereo updating ?
I have a FM1 with multiplex. After many years of service it had a leaky can cap. i replaced the can cap with discrete 400V caps. I also replaced several of the resistors (R11, 13, 15, 16, 21, 22, 23, 32 89 and 90). Now i need to align it. Tubes all tested fine.
I have the FM3 manual, is the FM1 alignment the same?
The manual says that "i" should be able to listen to the radio at this point. all i get is FM noise. Any ideas as to why? The voltages on the tube pins were low before, and are now over spec. If it was aligned with low voltage before, would that throw it so far out of alignment?
thanks for any suggestions
Updating the Dynaco Stereo 120 djoffe Solid State 62 23rd April 2012 12:24 AM
Dynaco Stereo 400 Amp andrew01 Solid State 5 19th June 2011 02:33 PM
Dynaco Stereo 70 amplifier Original Burnedfingers Tubes / Valves 231 30th December 2009 01:45 AM
Dynaco Stereo 400 mods XaQ Solid State 2 21st November 2005 06:13 AM
Need Help: Dynaco Stereo 120 amp jainbaby Solid State 4 18th December 2002 01:03 PM
Page generated in 0.06253 seconds (66.04% PHP - 33.96% MySQL) with 10 queries
