diyAudio Sponsor
Old 27th May 2011, 12:03 AM   #1
Default SE driver
A quick question...
Would the even harmonics generated by the driver tube cancel out in the secondary of the IT or continue on to the finals? See schematic.
Old 27th May 2011, 04:58 AM   #2
All what driver generates goes to the output tubes, since it is a SE-stage. Even harmonics generated by output tubes cancel out at OPT since it is a PP-stage.
Old 27th May 2011, 05:34 AM   #3
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
It depends on selected tube, it's idle current, and plate load resistance. See plate curves and load line. If you manage to get symmetric transfer curve even harmonics would be canceled.
The devil is not so terrible as his mathematical model!
Wavebourn: We Create Creativity!
Old 27th May 2011, 06:00 AM   #4
Where ? At the secondary of IT ?
Old 27th May 2011, 10:24 AM   #5
+1
both arto and wavebourn would be right as always...
I doubt if any cancellation would occur at the IT...
However the distortion spectra of the finals/OPT can be tailored to cancel out the distortion spectra of the driver tube as Wavebourn said....
Old 27th May 2011, 03:46 PM   #6
Wavebourn's Avatar
I said if the driver tube is biased and loaded such a way the stage has symmetric transfer curve, ...
Old 27th May 2011, 03:50 PM   #7
ok. got it.
I think I got mixed up with one of the other threads where they tried to match out of phase the distortion spectra of the finals stage to that of the driver stage so that it would cancel...
Tubelab SE Driver Bias Help SGregory Tubes / Valves 2 3rd January 2010 10:21 PM
Tubelab SE driver gain Klimon Tubes / Valves 5 27th June 2009 12:33 AM
Best driver for KT88 Triode SE. Kenneth Zhu Tubes / Valves 4 20th January 2008 05:19 AM
New driver for SE 2A3 camotecue Tubes / Valves 11 23rd August 2006 04:53 AM
What is the best input/driver for 2A3 SE? sgerus Tubes / Valves 51 8th March 2006 09:49 PM
Page generated in 0.08257 seconds (74.10% PHP - 25.90% MySQL) with 11 queries
