diyAudio Sponsor
Old 31st May 2011, 04:10 PM   #41
indianajo's Avatar
Originally Posted by famousmockingbird View Post
I was also looking at Sprague Atom (if I go the terminal strip route) and can't find info on them either.
Sprague atoms 1970 production are good for 25 years. No, they don't provide any data. I used to have the 1968 3000 page Sprague designer binder, but I lost it in a move.
Because modern rectifiers tend to short, I put a terminal strip in and put a resistor between the transformer and the rectifier. Also protects against oversize cap turn on surge. I've got 5AR4 rectifiers. 47 ohm 3 watt silicon coat wirewound is not big enough wattage- goes transparent when the surge hits it, then smells funny (but measures okay). Probably 5w is big enough, but I actually installed salvage resistors from a PCAT power supply, so don't know what wattage it is.
Dynakit ST70, ST120, PAS2,Hammond H182(2 ea),H112,A100,10-82TC,Peavey CS800S,SP2-XT's, T-300 HF Projs, Steinway console, Herald RA88a mixer, Wurlitzer 4500
Old 31st May 2011, 09:20 PM   #42
trobbins's Avatar
It's unlikely that 47uF would be too much, given that electrol's, especially old ones, would have had at least 20% tolerance ratings.
A good learning curve is to measure the primary winding and secondary winding resistances, and determine the effective secondary side source resistance. Then check the 6AX5 datasheet for max capacitance allowable to see if you have more latitude in choosing values. The forum would assist if you are unsure.
There are techniques for tweaking your options, by adding series secondary resistance or a primary side NTC resistor, but if you don't need to go there then KISS.
Old 31st May 2011, 09:57 PM   #43
Ron E is offline Ron E  United States
Ron E's Avatar
I heard an interesting story over the weekend, a comparison was made between a hotrodded (upgraded caps and boutique tubes) dynaco 70 and a stock one, and the stock one was preferred by a near unanimous vote. The hotrodder was mad.
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan
Science is a way of thinking much more than it is a body of knowledge. --Carl Sagan
Recapping a Perreaux 1150B amp? NH7RO Parts 42 23rd June 2011 09:49 AM
recapping peace brainerd Everything Else 3 20th February 2006 07:26 PM
Recapping optimization? kyrochan Solid State 0 26th October 2005 03:16 PM
Recapping questions MikeA57 Solid State 1 24th March 2005 08:57 PM
In recapping Amp - Choice of Caps? norman Tubes / Valves 4 5th January 2002 09:56 AM
Page generated in 0.08647 seconds (77.97% PHP - 22.03% MySQL) with 11 queries
