| diyAudio Sponsor | ||
I want to add a panel meter on my new amp project for bias. Anyone know what kind of meter i am looking for and maybe where they are available?
Thanks WO |
#2 |
You really need to see tube current, not bias voltage. Analogue amp-meter gauge connected straight to the tube cathode or digital mV-meter over cathode resistor will do. If using 1 Ohm cathode resistor, then 1mA = 1mV.
#3 |
If i go with the digital mV-meter what size? 0-75Mv? 0-200Mv? Thanks WO |
#4 |
#5 |
M = Mega, m=mili...
size depends on what your sense resistor value will be and the current you are sensing.. keeping it simple at 1ohm sense R.. then choose a meter with voltage that will cover the estimated bias/idle current... |
#6 |
I use 200mV digital meters.
If using 1 Ohm cathode resistor, then 1mV = 1mA. In this case 200mV mV-meter supports current measurements up to 200mA. If using 0,1 Ohm cathode resistor, then 1mV = 10 mA, this supports larger currents, up to 2A. Usually there is possibility to remove the decimal point from mV-meter, so the reading will be as the current. |
| Bias meter for AQ1008DT | tigro | Tubes / Valves | 0 | 8th October 2009 07:11 PM |
| bias meter and pot lead length | frank2395 | Tubes / Valves | 2 | 15th April 2005 11:47 PM |
| Calrad meter for monitoring bias aleph2 | Mattyo5 | Pass Labs | 16 | 7th January 2005 10:58 AM |
| bias meter | el capitan83 | Tubes / Valves | 4 | 20th December 2004 06:03 AM |
| Adding a bias meter to Zenlite | Michael Rothacher | Pass Labs | 11 | 4th February 2003 09:13 PM |
| Page generated in 0.08481 seconds (75.02% PHP - 24.98% MySQL) with 10 queries |
