diyAudio Sponsor
Old 26th May 2011, 06:55 AM   #1
ryuji is offline ryuji  United States
Default got a custom 829b amp that i got laying around, need to know what driver to use
my buddy sent this to me as a ride-on in a package of tubes he sent me a few months ago. I worked out with him/my own analysis that the power tube must be a 829b as it has screen connections, but what do people typically drive these with? ill be buying the 829 tubes so i wouldn't mind buying the intended/required driver tubes to have a listen to this amp
walking through the circuit, it seems like a double triode input, with anode of triode '1' being coupled to triode 2, and equal cathode+anode resistance on triode '2' and capacitors on both anode and cathode acting as phase inverter for the dual beam tetrodes?
if i remember right, the resistor leading to the double triode is 275k, and the grid 2 resistor for the power tube screen was about 5k, so im guessing about 300v b+?
got some 15w rated PP transformers laying around, i think it should be good enough long as i keep volume level down?
heres a picture if it means anything at all
Old 26th May 2011, 07:34 AM   #2
aardvarkash10's Avatar
sounds conventional triode voltage gain, triode cathodyne splitter, pp output. 15 w should be plenty in iron, around a 10k load. From memory the 829b needs around 18v pp of drive a g1 in pentode on a 10k load, so that starts to identify your other tubes...
I've got some 829b's sitting around and they are on the list for a build... maybe for my 60th birthday...
Yes, conservatism thrives on low intelligence and poor information. But the liberals in politics... continue to back off, yielding to the supremacy of the stupid. It's turkeys all the way down. - George Monbiot, guardian.co.uk, 6 Feb 2012
Old 26th May 2011, 01:27 PM   #3
mastodon's Avatar
As aardvaskash points out, it's a pretty common design. High impedance voltage amplification stage followed by a cathodyne splitter that's DC coupled to the input stage. Pinout is standard ECC/12AX type; I bet an ECC81 would work just fine there.
829B Based Amp silverchris Tubes / Valves 11 12th March 2012 10:26 AM
Trade Custom Speaker Horns for Custom Amp brsanko Tubes / Valves 3 6th July 2010 05:32 AM
Pete Millett's 829B amp -> monoblocks lochness Tubes / Valves 3 17th June 2008 12:30 AM
Page generated in 0.06949 seconds (70.29% PHP - 29.71% MySQL) with 10 queries
