#41 |
As you say there is a difference with AC and DC heaters, its interesting that the DC components in the supply of the heaters can also make a difference!
This is 50Hz and again the heating and cooling is not the issue. I think you would have to show a modulated idle current to prove this, I know it shows it in the link. However many here will argue the AC/DC heater issue also. I will look more closley at the link! Best wishes. Regards M. Gregg
What is the sound of one hand clapping? |
#42 | ||
His "study" doesn't "prove" anything. Yes. He posted some oscilloscope shots on a website and attached some graphics. But not anything I would consider documentation. It's not even clear what the oscilloscope shots show, what the vertical or horizontal scales are. Gimme a break.
Rod, rather than postulating, hypothesizing, and hand-waving, would you please share YOUR results? Specifically, I would like to see THD+N vs frequency and output power with an "amateurishly implemented DC supply" and your constant current source. If this "current mixing effect" really causes the distortion to skyrocket like you claim, it would be easy for you to measure and show the difference with/without your regulator. Any computer sound card along with free FFT software would be able to pick this up. Without hardcore data, your posts are really just fear mongering and pseudo-science. I don't understand why you are pushing this issue so hard. Last I posted anything related to DC filament supplies, I recall you did the same thing. Shouldn't it be up to the individual designer which circuit topology he chooses to use? What's your angle there? Just curious... ~Tom |
#43 | |||
работник
What Dmitry presents us with is a study of output magnitude and phase of DHT amplifiers, when the filament is fed from a selection of frequencies from 20 to 6000Hz. This is useful - to spell it out - to show that : - there is a current-modulation effect on the output of DHTs; - 2nd Harmonics are generated - the effect is frequency independent. - the phase relationship is stable and unchanged from the incoming signal. The last two items are of great interest, since they prove that this is NOT a simple capacitive coupling effect. Quote:
If it were a cap-coupled signal, the effect would increase with frequency, since the load at the grid is a resistor (50 to 100K). What's more, the 8pF or so of input capacitance of the 2A3 is over 800Mohm of reactance at 20Hz. The grid has a typically 100K pulldown. And yet -40 to -60dBV of 2nd harmonic was measured at the amplifier output. I would be interested to see your calculation that shows how such a feeble coupling could give such a large output as the -40dB V measured. For normally configured 2A3 amplifiers you'd get less than -140dB! Quote:
Tom, my Angle is simple. The forum is here to present ideas, debate the origin of problems, and discuss solutions. A big part of that is constructive criticism, and critical analysis. Filament heating is one of my pet topics, and there is no shortage of DIYers here who can vouch for the effectiveness of my solutions. I have offered some criticism of a solution you presented, and you seem to have interpreted it as an attack, and say that you are "not interested" in discussing the cardinal points of my analysis. As for presenting measurements, what reward would I have for all that considerable labour? I presented Dmitry's measurements, and you tried to misrepresent and belittle them, effectively labelling him a charlatan, despite it being a sincere and useful analysis. |
#44 | |
H. J. Van Der Bijl in The "Thermionic Vacuum Tube-Physics and Electronics" clearly explains the relationship between temperature and emissivity of at filament/heater. If the ac power through the the heater/filament does cause thermal changes it will be at a second harmonic of the line frequency and therefore indistinguishable from emissivity changes from second order harmonic emission from voltage e-field changes. Furthermore, he explains the difference in emissivity from one end to the other of a heated filament/heater, and how a potential difference along the heater effects emissivity along the heater (his analysis was done on an AC signal iirc, but equally applies to DC). Finally, given that there is a correlation between switcher noise on the filament and noise at the anode, what is the relationship between the 8mV 500KHz-800KHz switcher noise and audible sub-harmonics? Are there any? Last edited by TheGimp; 1st June 2011 at 01:23 PM. Reason: Corrected mv reading |
#45 | |||
работник
These add to this conduction-generated noise effects. Quote:
This means it is delivering energy to the output filter in pulses with low-frequency content, not just the 800kHz carrier frequency. The amount in the residual just depends on the quality of the supply input, and the (analogue) loop response of the switcher. This is added to other noise leakage paths, eg: during the ON time portion of the PWM, the input is connected to the output by a low impedance path, allowing other conducted emissions through to the filament in a piece-wise fashion. |
#46 | |
#47 |
работник
#48 |
Bingo! I would have preferred if he'd be willing to admit this himself. If his customers can hear a difference between constant voltage and constant current, more power to them (and him). But don't claim there is a *HUGE* quantifiable difference without backing it up with data. That's all I'm asking.
Some people also swear that they can hear a difference when they suspend their speaker cables on myrtlewood stands. Any other kind of wood or other inferior dielectrics just don't sound the same. ~Tom |
#49 | |
In the red corner we have....LOL Regards M. Gregg
What is the sound of one hand clapping? Last edited by M Gregg; 1st June 2011 at 03:41 PM. |
#50 | ||
You make the assumption that what he is measuring is due to this "current mixing effect" that you have thought up. Based on my understanding of how vacuum tubes work I just don't see that argument as being rooted in anything that goes on physically in the tube. Yes, the cathode current provides electrons for the filament coating to release. The filament coating releases electrons because it's heated by the filament current (DC or AC). But the process by which these electrons are released to the space-charge cloud surrounding the cathode is completely random. It's a stochastic process. To argue that you can distinguish one electron from another and follow this one electron as it travels happily from the heater wire to the anode is absurd and not supported by science. Quote:
You claimed earlier that a DC heater supply would cause all sorts of nastiness and result in severe degradation of the THD of the amplifier. You mentioned THD in excess of 4 %. Please back this up with data. If you are unwilling to take this data, would you allow me to borrow one of your regulators? I am perfectly willing to take the measurements for you and provide a true A/B comparison. I'm measuring 0.05~0.06 % THD+N with DC heating at 1 kHz, 1 W into 8 ohm. This is measured on this 300B amplifier speaker output using an HP8903A audio distortion analyzer. Once I get further with this filament heater design, I will be posting THD+N vs frequency and output power just like I have for any of the other amplifier designs I've posted here. I will also be posting complete schematics of the amplifier and filament regulators as I have for my other designs. Enjoy. ~Tom |
| Universal Tiger | aged one | Solid State | 232 | 5th December 2012 10:09 PM |
| Noisy IC Universal Regulator | dwalker0044 | Power Supplies | 4 | 14th April 2011 02:26 PM |
| Parallel vs. series filament supply - or another filament idea | engels | Tubes / Valves | 11 | 13th May 2007 01:06 PM |
