Universal filament regulator
Old 30th May 2011, 08:36 AM   #21
ryuji is offline ryuji  United States
not sure if you missed it in various buck converter application notes, but a second inductor+capacitor stage will reduce ripple, you can also try using a slightly larger inductance
go for the usual 10% rule of thumb for filter+inductor
i too am designing a buck converter, havent purchased any parts yet, however. Myself, im designing a 100mA to 5~8 amp 5~24v range regulator for powering various equipment unrelated to tubes with my friend... but i suppose it could be used for them too, huh
using microcontroller for feedback/real time control (going to be operating about 8 buck converters, plus monitoring thermocouples and voltages)
my specs so far are 220 uH and 10 uH with 470/47 uF capacitors, intend to use IRF3205 mosfets, waaay overkill but they are cheap and are very fast switching/easy to drive. havent decided yet on the diode
Old 30th May 2011, 09:36 AM   #22
trobbins is offline trobbins  Australia
trobbins's Avatar
ryuji, sometimes 'waaay overkill' in certain device parameters in smps can lead to poorer performance in other aspects. Eg. lowering Rds-on with fets typically leads to higher switching loss and emi. Balancing parameters is always a compromise.
Old 30th May 2011, 10:29 AM   #23
Rod Coleman is offline Rod Coleman  United Kingdom
работник
Rod Coleman's Avatar
Tom, The convenience is unbeatable, and for IDHTs it will be a winner. For
Directly Heated Triodes, though, the sonic performance will be some way short of
what is possible, for a number of reasons:
- Anode [plate] current in the filament: looking at the sketch attached, the
anode current flows in the filament substrate [ie the wire] to supply the
emission sites all along the length of the filament.
In a 300B DHT, running the standard 60mA, the portion of the filament nearest
FIL+ will carry the whole 60mA, with lower fractions of current found as you
work back toward FIL-.
Keeping Kirchoff in mind, the anode current and the Filament current flow
together indistinguishably in the filament wire. SO - Any disturbance in the
filament current supply will directly reflect as a disturbance in the anode
current - and remember, the 300B output is the anode current - it's not a
voltage!
This is a real risk to the quality of the 300B stage. Consider this: the little
10mV spikes on the switcher's output seem innocent enough - but what happens to
the current? Well the 300B filament is 5V 1.3A = 3.8 ohms [hot]. 10mV peaks give
2.7mA peaks of current in the filament.....which is imposed directly on the
anode current [since this is much higher impedance circuit than the filament
supply's]. This amounts to a 4.5% distortion current on 60mA. Of course, this is
mostly ultrasonic energy, but not entirely, since the duty-ratio of a
buck-converter bounces up & down with the input voltage, which in this case will
be the raw dc ripple and mains noise. This effect will produce large amounts of
spectrum at audio frequencies.
This current-mixing effect is the reason why simple Bridge + Cap dc heated DHTs
sound worse than any other heating method. In this case, the filament current is
modulated by many mA of ripple current, plus the rectifier recovery **current**
pulses, which start life at the 1.3A level equal to the dc current.
With ac heating, the effect of 50/60Hz current is cancelled by means of an
unbalanced pot, which equalises the 50/60Hz current in each half of the
filament. More accurately, it nearly cancels the current, since there is
second-harmonic distortion of the filament current, which does **not cancel** as
proved by Dmitry Nizhegorodov:
On Correlation Between Residual DHT Filament Hum and AC Frequency. Distortion-induced hum in directly-heated triodes.
ac heat also forces the anode current to be shunted around the transformer
secondary winding, where it is exposed to magnetic and electrostatic noise, and
bad dielectrics.
Other problems to be tackled:
With a switcher the output cap may be 100uF or so, which may present 50 ohms or
so at bass frequencies. This is shunting the filament, whose impedance is about
4 ohms at all audio frequecies, as above. Now we have the anode current taking a
frequency-selective diversion around the output cap, opening the risk of
colourations, both from the frequency-selective shunting, and from forcing
some of the anode current through electrolytic and high-K ceramic switcher-caps!
This is one of the reasons that a high-dynamic-impedance CCS improves DHT
heating, since the anode current remains contained within the cathode circuit,
and does not get diverted around the filament heating circuit.
The other reason CCS drive sounds so good is because the feedback for the
heating current does not sense at the filament terminals. This is important,
since the filament terminals do not distinguish between the anode-current
signal and the filament current, and you wind up mixing the anode current into
the closed loop of the heating current. CCS heating senses the filament supply
current ONLY, at the supply input, and does not sense or influence the anode
current in any way. This advantage cannot be had by any circuit which senses the
filament voltage.
CCS heating with 3-terminal regulator ICs also falls short - partly because
their input terminals do not adequately reject anode signals at the input, and
partly due to their excessive voltage noise, which translates into current
noise in the anode current.
folks who have tried my filament heater [from the last pages of the New DHT
Heater thread] often remark on the improvement over 317 or LT108x CCS heating.
Old 30th May 2011, 03:38 PM   #24
You have a good point, I was thinking they would be good for the purpose as I need them for other projects, might be worth getting more exact components
Old 30th May 2011, 07:11 PM   #25
tomchr is offline tomchr  Canada
tomchr's Avatar
As you can see from the oscilloscope shot I'm measuring 2~3 mVpp of ripple. It's hard to tell the magnitude exactly as it's approaching the measurement limit of the scope (Tek 2465B, P6139 probe). I'm really not concerned with it. Also, note that it's way out of the audio band.
For a filament heater, the 2~3 mV ripple will get smoothed out nicely by the thermal time constant of the filament. The question that remains is if it will couple to sensitive nodes in the circuit. I kinda doubt it - 800 kHz is not that high frequency and the coupling capacitances are in the pF range. It also hasn't been an issue in switching filament regulators I've built in the past. But, of course, it needs to be verified.
~Tom
Old 30th May 2011, 08:19 PM   #26
astouffer is offline astouffer  United States
astouffer's Avatar
Its happening at 800Khz, far higher than ultrasonic. That will be smoothed out because the heating time of the filament is not instant. It can only be modulated so fast.
Your AC line is not as clean as you think. Any low frequency garbage on it will go right through a transformer.
Old 30th May 2011, 08:32 PM   #27
работник
Naturally, the heating time-constant will suppress effects due to heating variation. But that is not the problem at all - it's the fact the filament current and the anode current are flowing in the same conductor, and that any noise, ripple or disturbance in the filament current will appear in the amplifier's output by simple conduction.
The switching may happen at 800kHz, but that's just the "carrier". A buck converter is just like a class D PWM amplifier, where the PWM duty is varying with the ripple and noise on the incoming raw dc. This certainly has audio frequency components, and this is what pollutes the DHT stage.
I agree, AC line is a terrible source of noise - my solution uses low capacitance [high insertion loss] buffering on **both** sides of the filament.
Old 30th May 2011, 09:06 PM   #28
tomchr's Avatar
Dear Rod,
I have absolutely no desire to turn this thread into a religious flame war about constant current vs constant voltage. But I do feel the need to at least address some of your concerns.
I have tried linear regulators (LM317 and the like) both for constant voltage and constant current. I also tried a lab supply that can be switched between constant current and constant voltage. I could not tell any difference between constant current or constant voltage neither in measurements nor in listening tests. The testing was done on my 300B amp (directly heated triode). I have also compared LM317, constant voltage to a switching regulator (LMZ12002). I could not tell any difference in sound between the different types of regulators. However, I did note that the switcher didn't result in any ill effects, the amp still measured and sounded well.
Even though the individual components of a switching regulator are more expensive than an LM317 and a few resistors, the switcher still wins on cost when the cost of the heatsink needed for the LM317 is considered. So same sound quality, lower cost, less heat to get rid of... The switcher sounds like a clear winner to me.
- Anode [plate] current in the filament: looking at the sketch attached, the anode current flows in the filament substrate [ie the wire] to supply the emission sites all along the length of the filament.
In a 300B DHT, running the standard 60mA, the portion of the filament nearest FIL+ will carry the whole 60mA, with lower fractions of current found as you work back toward FIL-.
You are making the assumption that one electron in the space-charge cloud is distinguishable from another. That argument is false. I'm sorry... Physics just don't work that way.
This is a real risk to the quality of the 300B stage. Consider this: the little 10mV spikes on the switcher's output seem innocent enough - but what happens to the current? Well the 300B filament is 5V 1.3A = 3.8 ohms [hot]. 10mV peaks give 2.7mA peaks of current in the filament.....which is imposed directly on the anode current [since this is much higher impedance circuit than the filament supply's]. This amounts to a 4.5% distortion current on 60mA.
If the switching spikes really caused 4.5 % distortion, I'm sure I would be able to pick it up with my HP 8903A distortion analyzer. It's noise/distortion floor is 0.002 % THD+N.
Of course, this is mostly ultrasonic energy, but not entirely, since the duty-ratio of a buck-converter bounces up & down with the input voltage, which in this case will be the raw dc ripple and mains noise. This effect will produce large amounts of spectrum at audio frequencies.
A well designed regulator (like any modern switching regulator) is designed to be as immune to variations in the input voltage as possible. This is characterized in a figure called line regulation. What you are describing above sounds like an unstable system. A well designed regulator is a stable system. A well designed regulator will provide a constant output voltage for any variation in load or input voltage (within limits, of course).
In any event, should this regulator turn into a happy bounce house with duty cycles varying all over the map and causing nasty, nasty audio frequency intermodulation products, I'm absolutely certain that it will be picked up by my HP 3562A dynamic signal analyzer. Its -145 dBV noise floor can hear the grass grow, trust me. In previous experiments, no switching-induced IM products were found. In fact the 120 Hz, and 240 Hz components were reduced by almost 20 dB by the switching supply due to its better line regulation.
This current-mixing effect is the reason why simple Bridge + Cap dc heated DHTs sound worse than any other heating method.
Except for the "current-mixing effect" which I believe is bogus as outlined above, I am willing to buy that statement. Double-rectified and smoothed DC is a rather nasty waveform with a lot of harmonic content. Also, in applications where significant current is drawn, the ripple voltage becomes harder to keep within reasonable limits. Hence, the amplitude of the nasty harmonic content becomes sizable and will couple into the circuit. This forms various IM products that can easily be picked up by a spectrum analyzer (such as the 3562A I mentioned before).
With ac heating, the effect of 50/60Hz current is cancelled by means of an unbalanced pot, which equalises the 50/60Hz current in each half of the filament.
Between the cathode/filament and grid is a coupling capacitor. This capacitor is not a real capacitor (i.e. physical component) but rather a parasitic capacitor. Unfortunately, the way physics work is that when you have two conductors in proximity of one another they form a capacitor whether you want it or not. So any AC voltage present on the cathode will couple to the grid (and anode). It doesn't matter if this voltage is the 2~3 mVpp @ 800 kHz that comes out of my regulator, or the ripple/noise that's present on the output of a constant current source regulator, or the AC from a filament winding on a transformer. But in case of the filament winding, the voltage on one end of the coupling cap is 6.3 VAC. That's a sizable voltage. By using a humdinger pot, this voltage is reduced to 3.15 VAC. That's how a humdinger works. It has nothing to do with electron emission. It's simple capacitive coupling.
ac heat also forces the anode current to be shunted around the transformer secondary winding, where it is exposed to magnetic and electrostatic noise, and bad dielectrics.
No it doesn't. Poor circuit design forces the anode current to return to the mains. In a well-designed circuit, the AC signal path for the anode current consists of the OPT, the output tube, and a high-quality cap from the cathode to the B+ end of the OPT primary. See Loftin-White for more information. This trick has been employed in modern measurement gear as well, by the way.
I did read through the rest of your response - including the website you linked to. I considered picking the arguments apart one by one, but as I said to begin with, I don't want this thread to turn into a flame war.
My fundamental point is this: A well-engineered, well-designed circuit will have superior performance over one that is not well-engineered or well-designed. I intend to design a filament regulator that performs well both when considered as a stand-alone voltage source and when used for a filament supply in either a directly headed triode or an indirectly heated tube. I will back up my claims with measurements and I will base my design decisions on facts and measured data. To me - as an engineer and a scientist - that's a reasonable approach. Others are free to disagree.
~Tom
Old 30th May 2011, 09:20 PM   #29
tomchr's Avatar
The whole purpose of having a regulator in the first place is to make the output of the regulator independent of the input. Any voltage regulator (be it switching or linear) compares the OUTPUT voltage to an internal reference voltage. The reference voltage is designed to be independent of the input voltage, temperature variations, etc. In silicon devices, a temperature compensated bandgap circuit is typically used. In discrete circuits, a zener or silicon bandgap IC may be used. In tube circuits, the predictable breakdown voltage of a neon (or other noble gas) bulb has been used. The line regulation (how efficient the regulator is at separating the output voltage from the input voltage) is generally dictated by how much the reference voltage varies with the input voltage. This is completely independent on the regulator topology used.
~Tom
Old 30th May 2011, 11:29 PM   #30
SpreadSpectrum is offline SpreadSpectrum  United States
SpreadSpectrum's Avatar
Tom, it looks like you have to solder the pad on the bottom of that thing as well. Is that pretty easy to do?
Universal filament regulatorHide this!Advertise here!
Universal Tiger aged one Solid State 237 17th December 2017 10:34 PM
Noisy IC Universal Regulator dwalker0044 Power Supplies 4 14th April 2011 02:26 PM
Parallel vs. series filament supply - or another filament idea engels Tubes / Valves 11 13th May 2007 01:06 PM
