diyAudio Sponsor
Old 25th May 2011, 10:10 PM   #1
dsavitsk's Avatar
Default ECC88 - 6DJ8 Cascode Plate Curves
Does anyone have plate curves for the ECC88/6DJ8 in Cascode? Lots of mentions of doing this, but I can't seem to put my hands on the data.
http://www.ecpaudio.com
Old 26th May 2011, 09:52 AM   #2
This any good? ECC88 @ The National Valve Museum
Old 26th May 2011, 10:40 AM   #3
revintage's Avatar
Did this manually in my AVO maybe 20 years ago as I didn´t find the curves. Used Excel to get the curves. Can see if I still have them. If I remember it right I just used the Sg-voltage to bias the upper grid. Should be doable with any tubetester.
Brgds
Lars
Old 26th May 2011, 11:08 AM   #4
DF96 is offline DF96  England
You can estimate from published curves.
Zeroth approximation:
Low triode works into a short circuit (vertical load line). Anode current merely goes through the upper triode - infinite Ra so curves are actually horizontal lines.
First approximation:
Low triode works into a load of 1/gm, so almost vertical load line. Upper triode sees lower triode as cathode degeneration resistor of Ra, so upper anode impedance is (mu+2)Ra. Curves are pentode-like.
Second approximation:
Remember that gm depends on current. This is when it gets messy.
Old 26th May 2011, 02:17 PM   #5
pmillett's Avatar
Not sure if it helps you any but the datasheets for some of my favorite "cheap alternates" have cascode curves... like the 6BK7 and 6BQ7:
http://www.mif.pg.gda.pl/homepages/f...93/6/6BK7B.pdf
http://www.mif.pg.gda.pl/homepages/f...93/6/6BQ7A.pdf
Pete
When life hands you a jeffery, stroke the furry wall.
Old 26th May 2011, 07:00 PM   #6
dsavitsk's Avatar
Great, that is helpful. Thanks.
Old 27th May 2011, 05:21 AM   #7
cerrem is offline cerrem  United States
I remember having the cascode curves for this tube somewhere...
I also remember the data sheets was written in Russian...so if you search the Russian tube makers website you might get lucky....
cerrem
Old 27th May 2011, 09:22 PM   #8
Merlinb is offline Merlinb  United Kingdom
ECC88 cascode curves with 50V on the upper grid.
Old 1st June 2011, 05:15 PM   #9
ruffrecords's Avatar
Is this what you need?
http://www.ianbell.ukfsn.org/pics/e88cc-phillips.pdf
Last page but one.
Cheers
Ian
Ian
FS tubes 6922/ECC88/6DJ8 merlin el mago Swap Meet 10 26th October 2010 09:47 AM
Morgan Jones and the ECC88/6922/6DJ8 rknize Tubes / Valves 75 18th April 2010 09:35 PM
What valves are pin compatible with ECC88 / 6DJ8? Merlinb Tubes / Valves 6 31st August 2009 05:12 AM
6DJ8/ECC88 mu-follower SSassen Tubes / Valves 30 11th April 2007 08:19 PM
WTB: 6DJ8 / ECC88 / 6922 Tubes mrdon Swap Meet 0 6th September 2005 09:58 PM
Page generated in 0.10519 seconds (78.94% PHP - 21.06% MySQL) with 11 queries
