diyAudio Sponsor
Old 26th May 2011, 08:14 AM   #11
Originally Posted by Conrad Hoffman View Post
Tube amps are in fact extremely robust. Either you have a problem that a competent tech should be able to locate quite quickly, or more likely you've been burned once and have sufficient paranoia that the amp can't sound right. The only way to fix that is do a blind comparison with some amp you regard highly. We're all subject to FUD (fear, uncertainty & doubt) and the results on our perception are very real. BTW, where are you?
Hi Conrad....I know all that and believe me..I am not paranoic..the amp. I am speaking about is CAYIN A 100 T....this is monster amp and it sounds like monster..heavy,deep bass as by SS..realy hiend amp...but now sounding like..let's say..amp for about 1000$...hope You have perception what I am speaking about...this terrific bass is just not there any more...now imagine You have bass control on the amp and take some 2-3 DB minus..so this is the effect I hear...and the highs are more present..of cousre I could listen the amp like that but that's why I bought this amp..because of his great bass and now it's gone...by the way I am from Croatia...small country near Italy
Old 26th May 2011, 11:14 AM   #12
DF96 is offline DF96  England
Has your "guru" checked the OPTs? Measure the primary inductance - this will show up shorted turns.
Old 26th May 2011, 01:13 PM   #13
Definitely do the measurements on the amp, but check the speakers too. Could there have been some spike that damaged a driver or crossover? Anything that affects the frequency balance could give the effect you describe.
Another thing to look at is the current draw of the amp and the temperature of the transformers. If there's a shorted turn I'd expect the power consumption to go up, especially if it's in the power transformer. It would run warmer than normal. The problem is that if the change is subtle, it will be hard to tell without prior data on what's normal for the amp.
I used to be an audiophool like you but then I took an arrow to the knee.
Old 30th May 2011, 09:47 PM   #14
Thank You for so much help..thanks..I appreciate that...but..I sold the Cayin and already have new monster but this time and 500 w UPS perfect sinus,double conversion....now the amp. is always conected on battery..no more black outs..this is special UPS for HI FI equipement giving no break power of 220 v + - 2%...so...now to the amp...MING DA MC-34-AB...out of the box..sound is FANTASTIC..SUCH TREMNDOUS,dinamic stage and space,such live feeling..realy happy about it....2 6SN7 Onion shape are realy much better then Electro Harmonix 6sn7 ...only input 12AT7 I will put there Tung-sol for the begining...but I realize that my speakers which are 4 ohm sound much,much better conected on 8 ohm port of the amp...how 's that possible????...another question...which 12AT7 would be the best deal for this amp?
FS: Quad 99 Power Amp - Black datawolf Swap Meet 0 16th November 2010 11:48 AM
Black & Decker CI 500 Rullknufs Equipment & Tools 6 25th September 2010 10:52 PM
For sale Bowers and Wilkins B& W Xt4 in Metallic Black nkvd7a7 Swap Meet 0 21st December 2009 11:16 PM
MANY & BIG & NEW High-power black anodized extruded aluminium HEATSINKS for sale cocolino Swap Meet 18 5th December 2006 07:39 AM
Black gate types C & Std etc tubenut Analog Line Level 2 4th August 2005 09:43 PM
Page generated in 0.08900 seconds (79.83% PHP - 20.17% MySQL) with 10 queries
