diyAudio Sponsor
Old 24th May 2011, 02:15 PM   #1
WildOne's Avatar
Default I am collecting parts for my 200w mono amps "But"
I have been collecting parts for a few large output amps. I want to do one 200w stereo all on one chassis and then I want to do a pair of 200w mono amps,
I know this is a huge adventure, I am up to the Challenge as long as I have good help.
I have the power. and the tubes what I need is a good schematic to go off of? Looking for a simple 100w per side stereo schematic to start! This will be the first one I start off with.
Tubes will be 6550's
I have some parts, But will need to order most of all the other parts needed,
Here is a few pics of the trannies I have to work with. The smallest ones are Chokes for the 200w mono's. then next up is the 100w OPT with labels and the the others with the label next size up is the PS for the 100w and then the monster 12.5lb 200w OPT and then the large Grey PS for them.
This is not going to be cheap! Just these are a big bite But they will be all custom hand made one of a kind amps made by me!
I may do a stone chassis and then do pillars of stone with the sockets inside for the tubes. And then carve all over it.
It will not look like all the others I have here. I am going way outside the box on this design. Way out!
I want to thank you for your help!
WO
Old 24th May 2011, 02:56 PM   #2
Loren42 is offline Loren42  United States
You might want to look at the new KT120s instead of the 6550s, but it may be too early to tell exactly how well they will sonically perform.
Old 24th May 2011, 04:46 PM   #3
richwalters's Avatar
Parallel p-p KT90 is my current tack 2K A-A 40% UL taps...The electro harmonix versions which I have on a timer (1500hrs) are behaving consistently with 40W anode dissipation.
TungSol 6550 New edit, I found a disappointment, the best I've ever got is 150W from parallel pairs and they didn't last long. Modern day KT88's fall into the same trap, there is only one I found that can take punishment and that was the JJ version.
richy
Old 24th May 2011, 05:03 PM   #4
Maybe a good question to ask is why do you need so much power?
Old 24th May 2011, 06:00 PM   #5
DF96 is offline DF96  England
Is this an amp for listening to or looking at?
Old 24th May 2011, 06:08 PM   #6
jlsem is offline jlsem  United States
jlsem's Avatar
Why does someone always have to start something?
John
Old 24th May 2011, 06:13 PM   #7
SY's Avatar
John
If you don't, they sit there inert, cold, and unable to pass music through. Starting them up is critical to making them run.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 24th May 2011, 06:19 PM   #8
tomchr is online now tomchr  United States
tomchr's Avatar
John
No kidding!! I'd be happy if I could just FINISH my projects.
~Tom
Old 24th May 2011, 06:20 PM   #9
WildOne's Avatar
They are for show and tell!
I want them to sit on top of the K-horns. I know I do not need no where this power but I am on this path and no stopping me now,
I should be able to get 25w x 4 of the 6550s with no problem? Don't you think?
Any idea's on a schematic?
WO
Old 24th May 2011, 06:33 PM   #10
SY's Avatar
K-Horns? 10 watts will blow the roof off.
Omtec Mono Power Amplifier "CA 25" (CA25) - Schematic wanted tiefbassuebertr Solid State 0 9th February 2010 03:56 PM
What makes an amplifier "bright", "warm", or "neutral"? JohnS Solid State 51 13th December 2009 06:42 PM
"WTB" 300b Integrated or mono blocks markmelheim Swap Meet 0 19th February 2009 12:20 AM
Kofi Annan in: "Seven-Pound Mono Amp" Kofi Annan Tubes / Valves 20 26th November 2006 02:58 AM
How "mono" is your mono power supply? yldouright Solid State 21 24th November 2003 03:20 PM
Page generated in 0.09980 seconds (77.73% PHP - 22.27% MySQL) with 11 queries
