| diyAudio Sponsor | ||
I just checked some datasheets for 6V6 tubes and i found two sets of plate current curves. On one of them the grid voltage goes positive. could someone explain the difference between the two sets? Which one should i use???
thanks |
#2 |
Where they coincide (e.g. negative grid) the two sets of curves should be the same, although perhaps on different scales. The positive grid curves would be used for Class AB2 or C. For most audio purposes use the negative grid curves.
#3 | |
You could use any one, depending on what you're designing. For the most part, audio work would use the set that ends with Vgk= 0. Back in the day, 6V6s were used a lot in RF applications, usually as frequency multipliers and intermediate drivers (Class C) in ham rigs. If you want more audio power than thye suggested audio operating conditions, you could drive the grids positive for Class AB2, depending on loadlines, plate bias currents, and plate dissipation. Not done very often back in "the day", since Class AB2, Class B, wasn't so easy to implement if good sonic performance was the design goal. These days, a MOSFET source follower can easily drive grid current at very low source impedances for excellent sonic performance. |
#4 |
| 6v6 SEP | Mosquito | Tubes / Valves | 31 | 26th December 2010 03:08 PM |
| 6V6 Output? | Psychobiker | Tubes / Valves | 15 | 29th March 2008 03:23 AM |
| max b+ for 6V6 | SemperFi | Tubes / Valves | 5 | 5th June 2007 07:18 AM |
| 6aq5.......6v6....... | diesel_tech | Tubes / Valves | 9 | 23rd February 2007 12:43 AM |
| 6v6 schems | amp builder jb | Tubes / Valves | 6 | 21st July 2005 08:38 PM |
| Page generated in 0.06755 seconds (74.87% PHP - 25.13% MySQL) with 10 queries |
