diyAudio Sponsor
Old 23rd May 2011, 03:43 PM   #1
NYCOne is offline NYCOne  United States
Default Recommended Tube/Valve references?
I've learned a bit on the SS side of amp building, and I've built a few Nelson Pass style amps.
I'm interested in learning about Tube/Valve amp design and building. Can someone recommend some references? When I Google, the responses are quite repetitive and not as specific as I'd hoped.
I'm curious about differences between tubes, general design, direct heating, power supply design, etc.
Old 23rd May 2011, 04:17 PM   #2
kevinkr's Avatar
Get Morgan Jones' "Valve Amplifiers 3rd Edition" and "Building Valve Amplifiers" - both are entertaining and chock full of relevant tube audio design information, comprehensible theory, and projects.
www.kta-hifi.net
Old 23rd May 2011, 09:49 PM   #3
Miles Prower's Avatar
I've learned a bit on the SS side of amp building, and I've built a few Nelson Pass style amps. I'm interested in learning about Tube/Valve amp design and building. Can someone recommend some references?
Most of what you know transfers. As for references, Pete Millet's Site probably has what you're looking for. Read the synopsis for each to decide what's right for you.
There are no foxes in atheistholes
www.dolphin-hsl.com
Old 23rd May 2011, 09:55 PM   #4
SY's Avatar
Second that! Morgan's books are comprehensive, accurate, and he has a teacher's knack.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 23rd May 2011, 11:00 PM   #5
ChrisA is offline ChrisA  United States
Yes, Pete Millet's site is good. One book he has there that is really "The Bible" is "Radiotron 4th ed.". The author tends to explain every subject first in simple terms, then goes back and covers more details and then makes a third pass. So you read as much as you like on each subject. (about 1,500 pages)
http://www.tubebooks.org/Books/RDH4.pdf
Read the first couple pages in each chapter and you will know more than most people.
A good web site that is at about the technical level of the Morgan Jones book is at the link below.
Merlin's style is also much like Morgan Jones. Both are easy to understand without being dumbed down.
It covers guitar amps but the basic theory is the same.
http://www.freewebs.com/valvewizard/
He has a PDF file that is a good introduction and covers triodes. This is the foundation of everything else.
http://www.freewebs.com/valvewizard1...Gain_Stage.pdf
I think the above PDF file is the best introduction to designing with values you'll find.
Old 24th May 2011, 12:52 AM   #6
boywonder's Avatar
Turner Audio has some great educational stuff:
education+diy
Recommended upgrades for Yaqin Tube Buffer ? Galgo Tubes / Valves 5 4th July 2010 01:47 PM
can't find valve art tube - and glowey tube pic wicked1 Tubes / Valves 23 10th February 2009 12:54 AM
Tube Manufactures Cross references Trout Tubes / Valves 4 30th December 2004 05:23 AM
Recommended Tube Books for DIY Eric Tubes / Valves 12 6th February 2002 07:54 PM
Page generated in 0.09397 seconds (74.12% PHP - 25.88% MySQL) with 10 queries
