diyAudio Sponsor
Old 22nd May 2011, 04:09 PM   #1
JTCamp is offline JTCamp  United States
Default More k12g amp musings
Much thanks to soonerorlater for all of the help with my recent questions.
I installed a standby switch which helps a lot with the popping when turning off the amp. After some cleaning the amp seems to be running fine, no more drastic differences between channels or dropping of the left channel.
However I am curious if there is a good way to check channel balance with a multimeter?? I am also possibly coming into an oscilloscope...would I be able to do the above test with it? I suspect it will come in handy for checking but I'm not at all familiar with them! Excited to learn! What do you'll think? Oscilloscope or not?
Thanks so much
John
My First Tube Amp Build: S5 K12G DisasterArea Tubes / Valves 7 8th February 2011 09:47 PM
K12G left channel dead: HELP! DisasterArea Tubes / Valves 3 16th December 2010 09:21 PM
HELP!! Howling K12G!! Jeffree59 Tubes / Valves 13 8th April 2010 11:30 PM
K12M / K12G Current Draw wa5znu Tubes / Valves 1 12th December 2009 05:12 PM
Wurlitzer/Fisher Amp Musings wrenchone Tubes / Valves 2 10th August 2008 10:41 PM
Page generated in 0.06931 seconds (65.12% PHP - 34.88% MySQL) with 10 queries
