| diyAudio Sponsor | ||
#11 |
This device may require a minimum load current to function properly. I believe that
minimum load is 10ma. If you are powering it up without a load then the current through rr2 and rr3 may be below this minimum value. You might try just shorting rr2 or placing a load on the output to se if this is the problem. |
#12 | |
You also need a reasonably sized heat sink on the LM317. If the chip overheats, it'll enter thermal shutdown. Three bad pots?! Actually, that sounds like you either didn't hook the components up according to the schematic or there's a cold solder joint somewhere. ~Tom |
#13 |
#14 | |
With 120 ohm from OUT to ADJ, you already draw 10 mA through the regulator. No additional load needed for regulation. ~Tom |
#15 |
Yes, I can now adjust the output voltage with the trim potentiometer. It could have been a cold joint, I guess. I'm still not a master at soldering
| a free but not working Stabylex 12 VDC power supply to any one | giggleherz | Power Supplies | 3 | 18th April 2010 05:14 PM |
| 12 vdc to 18 vdc isolated P-P | jamesrnz | Power Supplies | 89 | 4th February 2009 03:36 PM |
| schematic for 12.6 VDC heaters | cbutterworth | Tubes / Valves | 7 | 5th March 2007 07:09 PM |
| 48 VDC Power Supply construction ?s | PaulHilgeman | Parts | 2 | 15th January 2003 12:14 PM |
| Using fuses on VDC Power Supply Rail? | Lucas_G | Pass Labs | 4 | 22nd December 2002 09:37 PM |
| Page generated in 0.07214 seconds (73.67% PHP - 26.33% MySQL) with 10 queries |
