| diyAudio Sponsor | ||
Hi, I have a valuable & rare tube with a broken pin - its sheared at the glass interface, but is still gas-tight. Before you ask, it came this way
![]() Can this be repaired by a glass/neon shop, i.e. have a new bit fixed to the end of the old? Ideas? Thanks
Nicko "The whole plan hinged upon the natural curiosity of potatoes" - S. Lem |
#2 |
Hmm....
I wouldnt have thought so.... I used a pin (sewing type) a small spring and a connecting lead, modded up a socket so the pin protruded against the 'stump' of the broken tube-pin on a CRT many years ago. It was a G1 pin so no current--it worked fine.... All according what pin/current the tube draws through the broken pin will govern success of this method--but at least you stand a chance without possible further breakage of the valve itself.... |
#3 |
Magneto the Gravity Man
Sell it on Ebay !!
If it is really valuable, some idiot will pay for it even broken. Put it on at an absurdly high Buy-it-Now price with offers. Andy .
If it ain't broke, break it !! Then fix it again. It's called DIY ! |
#4 |
Out of curiosity, What valve is it...?
#5 |
CSF F9020AA - a display rather than audio tube, extraordinarily rare, typical cost (if you ever find one) somewhere north of USD 350 (and have gone for over USD 500).
Anyway, there's enough usable pin stub for get a sprung pin onto, so made a holder from acrylic and its now fine (pin current is only 5mA). Cheers
Nicko "The whole plan hinged upon the natural curiosity of potatoes" - S. Lem Last edited by nickds1; 25th May 2011 at 08:01 PM. |
| 845 tube - pins have 4 collet connections | mreichler | Parts | 0 | 19th July 2010 09:14 AM |
| Help cleaning tube pins | astouffer | Tubes / Valves | 10 | 11th December 2007 07:51 AM |
| what's the purpose of pins 3 and 7 in an 8pin VR tube? | jarthel | Tubes / Valves | 7 | 9th May 2007 01:42 PM |
| Broken Carver Pre-Amp -- need help repairing | sundownz | Digital Source | 7 | 11th April 2005 03:02 AM |
| Cleaning oxidised tube pins. | JoeBob | Tubes / Valves | 18 | 21st August 2002 03:18 AM |
| Page generated in 0.08791 seconds (78.91% PHP - 21.09% MySQL) with 10 queries |
