diyAudio Sponsor
Old 20th May 2011, 09:46 AM   #1
Default Low emissions
I'm wondering what effects does low emission capability have on tubes. It's obvious that with lower emissions the maximum cathode current is reduced. What else changes? Mainly my concern is plate resistance and thus the curves.
Is there any difference with low emissions from age and wear, or low emissions on account of sub spec heater voltage?
Are curves measured in a low emission situation reliable (at least at lower cathode currents)?
Old 20th May 2011, 10:34 AM   #2
DF96 is offline DF96  England
Low emission is likely to mean that current and gm go down. As mu will remain largely unchanged, the anode impedance will rise. This means that, on average, a triode circuit will survive valve ageing better than a pentode circuit - triode amplification is largely set by mu, but pentode amplification largely by gm.
Low noise, low microphony, low hum valves MarcelvdG Tubes / Valves 28 31st December 2010 09:41 AM
preamp supply LOW power LOW noise LOW cost drdagor Power Supplies 1 13th September 2010 11:39 PM
Extremely low power and low loss transformers percy Tubes / Valves 12 23rd February 2005 10:30 AM
how low is 'low DC' on SOZ outputs? psarin Pass Labs 8 8th March 2002 01:39 PM
Page generated in 0.05234 seconds (72.34% PHP - 27.66% MySQL) with 10 queries
