Vacuum Tube OTL power amp!!
Old 16th October 2012, 11:06 PM   #821
M Gregg is offline M Gregg  England
More trial and error..
Well initial tests are interesting, I'm Running 410V across the rails. 205v app across each 6C33C. I am running mixed bias 42V on the top tube. the bottonm tube is adjustable to get a balance across the 150 Ohm cathode resistors. The PSU caps are balanced with 10K and 22K.
I am still running the MU sections with the FETs at the moment..I will look at how low I can get the cathode resistors and still have some sort of control. Idle current is set at approx 200mA. So I'm getting about 25V single heater and 30 Volt dual heater across the 150 Ohm Cathode resistors.
The supply is now not CT and floating..bass is still good! Some more tweeking to do..
I still have the Auto bias sound at the moment, however its a bit louder..Perhaps more open as well.
Its all Good fun.... The only problem is the stink off the power resistors as they burn in....or Out depends on your point of view....
M. Gregg
Old 16th October 2012, 11:32 PM   #822
I should add,
The choke psu is staying...
The bias was created with a voltage doubler giving about 100V from a 50V winding on the new higher voltage power Tx.
The top tube bias from the bottom tube power rail..
So the saga continues...
Nothing like playing for fun is there.. Oh well bed I suppose...more playing tomorrow....
M. Gregg
Old 19th October 2012, 03:36 PM   #823
Well,
Discussion in the background....
The 1st stage is still MU, 2nd stage is resistor anode, direct coupled to PI no grid stopper.
Combined with the mixed bias and increased main HT (410V) gives me switchable one and two heaters. Volume is way better. Using Ansar coupling between PI and 6C33c, Robert Hovland super cap between 1st MU stage and 2nd stage driver direct coupled to PI. Bass drive is good..
I think there is still room to reduce the cathode resistors and increase DC bias. Its run in time again and test (on full power at the moment you can't shout and be heard)(mozeners still in place) so the saga continues...
Hum is ear in the speaker low...sound stage is good.
It would be interesting to try some kind of direct drive with the 6c33c's.
Perhaps another project...
Something I found strange is it sounds better with the Goss band removed from the main power TX..wonder why<<perhaps its imagination...
The cork pads work well under the toroid for isolation...(just for interest).
M. Gregg
Old 19th October 2012, 06:20 PM   #824
azazello is offline azazello  Bulgaria
azazello's Avatar
Originally Posted by Matthewong View Post
Hi, would like to ask whether the vacuum tube OTL power amp worth to build? How is the sound performance if compare to normal output transformer type?? Does anyone has any good schematic diagram for OTL power amp, can share out, thinking to try to make one.
I made OTL - 6AS7 /sorry, very ugly, but this is only try/according this schematic:
diytube.com :: View topic - OTL amplifier
Before phase splitter I put preampl. 1/2PCC88.
Current plate every 1/2 6AS7 - 70 ma. -Ubias about 90 V.
U under 820 + 820 ohm is 0 /no more 100 mV/, because currents upper and down shoulders in different direction
must be the sames, for avoid U under speakers. You can connect fast fuss 300-500 ma to save speakers and voltmeter. In the begin, after switching, there is some U, after few minutes U must be min. and You can connect speakers. There isn't cathode shunts for 6AS7 /like for 6S33S, I think that its sound is some sharp/ that will paint the sound, that is very important!
Sound is cool, awesome! The scene is very deep, bass is giant, details are unbelievable. /Now I can't listen my SE 300B, 2A3....with output transf., because every OT press Low Freq. and the scene, IMHO /.
Old 20th October 2012, 03:24 PM   #825
Hi azazello,
I dont seem to be able to find the modified schematic of the preamp ecc88?
Did you put it after the volume control or before it?
Did you use any speaker protection? (on the psu or other)
and are you timing in the connection to the speakers? (after bias offset settles at start up).
M. Gregg
Old 20th October 2012, 05:48 PM   #826
azazello's Avatar
For preamp. PCC88: +U = 270v, Rplate=20kohm, +Uplate=138v, Rcathode=390ohm, I plate=about 7 ma, Ucathode=2.7v., Rgride= about 500 kohm. Interstage cap about 470 nF. Potentiometer /about 2 - 10 kohm/ is in input.
My speakers are Fostex 206E - 8 ohm. 96 dB, for protection I use fast fuss in serial to speaker, depending how I can hear the level of the sound in my room. My speakers are with High sensitivity, volume is small and I use fuss 300 ma /with 100ma fuss is blowing/. I know that speakers never will die. For speakers with low sensitivity, fuss will be more, You will try.../I don't know how is the diameter of wire of Fostex 206E and how is max. current across the coil of speaker to decide what kind of fuss use/. For ex: If one from 4 triodes will die, U cathode res. will be 5-6 v, Current across 8 ohm will be about 700 ma, there are more wrong situations and wrong currents are different.
Waiting time to setting common current across common cathode resistor is about 3 min. After this I will connect speakers./Common current is +- about 100 mV. If all triodes are identical, U will be about zero/.
Old 20th October 2012, 06:25 PM   #827
azazello's Avatar
Sorry, I will add: Cathode shunt cap of PCC88 is 1000-1500 uF Nichicon or Elna, or Rubycon.
Old 20th June 2014, 07:16 AM   #828
ballpencil is offline ballpencil  Indonesia
Holy thread revival, Batman!
I'm gathering the parts to make yet another Technics Futterman 6c33 OTL Amplifier. It will be all Russian tubes with cathode bias on the lower 6c33 and adjustable grid bias on the upper for that absolute minimum zero volts on the speaker outputs, regardless of how unmatched those tubes are.
Anyone care to comment on schematic? Especially about whether there is enough voltage swing from the phase inverter and if the PI's bias current is enough to drive a 6C33. Here's the designed load-line.
Old 20th June 2014, 08:31 AM   #829
Kay Pirinha is offline Kay Pirinha  Germany
Kay Pirinha's Avatar
I think that cathode biasing ain't no good idea for output valves in an OTL circuitry. These valves, in this configuration, necessarily will run in class AB with relatively (in comparison to the AC output current) low idle current. Driving the amp into significant output power simply will increase the negative bias voltage of the relevant valve too much.
*Imho* it is better to bias one valve by a fixed, but adjustible grid voltage, and to servo bias the other one in order to achieve symmetry.
Best regards, Uwe
Old 20th June 2014, 01:42 PM   #830
Ketje is offline Ketje  Belgium
Ketje's Avatar
Mona
Vacuum Tube OTL power amp!!Hide this!Advertise here!
FS: Vacuum Tube Monoblock Power Amp Kit cuibono Swap Meet 13 7th May 2011 12:49 AM
Vacuum tube VCO Bitrex Instruments and Amps 1 15th March 2011 12:07 PM
HLLY MK III 3 Vacuum Tube Headphone Amplifier Pre Amp hllyelec Vendor's Bazaar 2 19th July 2009 05:54 AM
S3E Vacuum Tube angsuman Tubes / Valves 12 15th March 2008 05:12 AM
DIY Vacuum tube amp turbo_h4 Tubes / Valves 2 1st July 2004 01:48 AM
