#811 |
LOOKS IMPRESSIVE
Esteban Bikic |
#812 |
Cool! Any idea why the toroids are buzzing? Are you for example saturating the core every half cycle - if so some very small power resistors in series with windings might get you out of the woods by limiting the peak current to something more reasonable..
Mechanical buzzing - can you isolate the toroids on sorbothane mats or similar?
"Extraordinary claims require extraordinary evidence." - Carl Sagan |
#813 |
First i suspected DC from the mains since it sometimes is dead silent and some other times buzz loudly.
A DC-trap didnīt change the behavior. So either a badly fabricated toroid or something i missed ?? |
#814 |
When you say 'DC trap' this was something on the mains side of the transformer? A set of diodes bypassed by electrolytics? If no, then you need to add this, if yes, noisy transformer.
#815 |
Yes, tried from 2-7v diode drop on the mains side same result so must be the toroid itself.
OR..??? Strange that it comes and goes. A noisy toroid could change during heatup, but this comes and goes. |
#816 |
Were the diodes bypassed by electrolytic capacitors?
#817 |
Yes.
2pcs 10mF back to back. |
#818 |
Hm. I would try something more like 1000uf...
#819 |
#820 | |
You must mean 'mill' as in milli-farad'? If that is true then you will simply have to replace the toroid(s) or find some way to isometrically isolate them from the chassis. |
| FS: Vacuum Tube Monoblock Power Amp Kit | cuibono | Swap Meet | 13 | 7th May 2011 12:49 AM |
| Vacuum tube VCO | Bitrex | Tubes / Valves | 1 | 15th March 2011 12:07 PM |
| HLLY MK III 3 Vacuum Tube Headphone Amplifier Pre Amp | hllyelec | Vendor's Bazaar | 2 | 19th July 2009 05:54 AM |
| S3E Vacuum Tube | angsuman | Tubes / Valves | 12 | 15th March 2008 05:12 AM |
| DIY Vacuum tube amp | turbo_h4 | Tubes / Valves | 2 | 1st July 2004 01:48 AM |
| Page generated in 0.10737 seconds (100.00% PHP - 0% MySQL) with 10 queries |
