Vacuum Tube OTL power amp!!
Old 26th May 2012, 08:44 AM   #781
Kay Pirinha is offline Kay Pirinha  Germany
Kay Pirinha's Avatar
Originally Posted by atmasphere View Post
They seem to have very high plate current ratings- 1.4 Amps!
According to the Sylvania datasheet this also means peak current!
Best regards!
Old 26th May 2012, 10:35 AM   #782
M Gregg is offline M Gregg  England
Originally Posted by banat View Post
Hi
My experience with PL519 tube is that specified Philips data is valid but for only very short time of peak cathode current , of few milisecond duration , in real life tube PL519 will blown internal cathode to tube pin link easy and fast , that is actually the weak point of this tube , similar case is with tubes PL509 , EL519 and El509 , regardless to tube manufacture brand .
PL504 tube don`t suffer from this internal over current peak contact link failure , it is pretty rugged tube .
Best Regards for all !
Do you know to any good PL504 OTL schematics?
M. Gregg
Old 26th May 2012, 03:17 PM   #783
banat is offline banat  Serbia
Hi Mr.Gregg !
The best PL504 OTL Amp solution for everyday 24/7 use will be small amp with triode connected 4xPL504 per channel driving 4 x 8 ohm speaker = 32 ohm , or even little higher impedance , based on Atmasphere M60 topolology only !
For higher output power and lower speaker impedance just insert more PL504 tube in parallel .
Special want to point Atmasphere driver DC coupled circuit which is the best solution for full control over PL504 power tubes , but for best possible Amp sonic to .
Atmasphere input voltage gain stage is OK to , but there is only small place for modification and tweaking to .
Best Regards !
Old 27th May 2012, 02:07 PM   #784
Thank's for the reply,
Where can I get a look at the M60 circuit?
What is the optimum number of pl504's for 16 Ohms or is 8ohm not viable?
I guess the DC coupling stops capacitor blocking?
M. Gregg
Old 27th May 2012, 02:49 PM   #785
Dimitris AR is offline Dimitris AR  Greece
Hi banat , or PL36 triode connected too
Old 27th May 2012, 04:30 PM   #786
M. Gregg
M.Gregg
Complete Atma-Sphere M60 DIY article with full DIY support from Mr.Ralph Karsten ( Atmasphere ) you can found here :http://www.diyaudio.com/forums/tubes...ube-amp-2.html
For 16 ohm speaker you need about 6 or 8 PL504 tubes .
Yes DC coupling driver avoid effect of blocking distortion , but permit A/A2 class of operation for output power tubes with superb sound performance.
BTW , universal good solution for optimum match to relative low output power OTL Amp is to connect 4 or more standard 8 ohm speaker in series , since today is possible to by very good quality speaker unit for relative low money , before 30 or 40 year ago that was not possible .
Best Regards !
Old 27th May 2012, 04:40 PM   #787
Yes !
BTW , I prove the excellent quality of PL36 tube on output RF power stage for AM Pirate transmitter , the PL36 stand 1KV B+ with no problem for years , PL504 up to 1,3KV , and PL519 up to 1,5 KV , but PL519 very often flash & burn the cathode to tube pin link , PL 36 & PL504 never .
Best Regards !
Old 27th May 2012, 08:50 PM   #788
I never experimented with PL36 in RF power stage , but I use it in my Futterman OTL ( triode connected ) a long time ago, about 8 years without any problem it's really a good tube, and in the last 7 months in an Circlotron OTL triode connected too but with AC coupling driver , with 10 PL36 in each channel I have output impedance of 1.2Ω which is pretty good result .
Old 27th May 2012, 09:17 PM   #789
Dimitris
That`s nice results
Have attention on Russian 6p13c (6p13s) tube , it is same as EL36 tube , it`s cheap tube but even more rugged as any European couterpart .
BTW , for once try DC coupled driver stage , bipolar suplyed , it`s worth !
Old 27th May 2012, 10:01 PM   #790
Thanks banat .Yes , good idea , I will try 6p13s in the next OTL project with DC coupling driver to see the differences , it's difficult to try it now because there is no space inside the amp at all for extra power supplies .
Vacuum Tube OTL power amp!!Hide this!Advertise here!
FS: Vacuum Tube Monoblock Power Amp Kit cuibono Swap Meet 13 7th May 2011 12:49 AM
Vacuum tube VCO Bitrex Instruments and Amps 1 15th March 2011 12:07 PM
HLLY MK III 3 Vacuum Tube Headphone Amplifier Pre Amp hllyelec Vendor's Bazaar 2 19th July 2009 05:54 AM
S3E Vacuum Tube angsuman Tubes / Valves 12 15th March 2008 05:12 AM
DIY Vacuum tube amp turbo_h4 Tubes / Valves 2 1st July 2004 01:48 AM
