Vacuum Tube OTL power amp!! - Page 73 - diyAudio
Old 6th January 2012, 08:48 AM   #721
M Gregg is offline M Gregg  England
Originally Posted by Alastair E View Post
Worth remembering the Impedance presented to the amp by the speaker at or near its freq of resonance, --for the Alpair 7 70 Hz, its many times the DC or quoted nominal impedance...
For the Alpair, its approaching something like 50 ohms at 70 Hz, therefore an easier load for the amp and more effective power can be realised.....
The only trouble is..
When you power them for the first time you can only have them at transistor radio volumes (I have a feeling you would damage them if you try to push them their so tight) and they produce what sounds like "0" bass...Then a very slow break in period over 6 Months..LOL
Then your stuffing polyfluff in the vent to reduce the bass...cuz its so loud..LOL
M. Gregg
Old 17th January 2012, 10:42 AM   #722
Yes i see it
Old 28th January 2012, 03:47 PM   #723
OK just an update,
The toroids now have cork pads under the rubber pads made from cork tiles..
Result reduced Tx noise (mechanical)..
(Tx under rated no heat issue)
The 0.22 interstage cap was changed just for a laugh to Obbligato 630V <<(seem to like violin don't know why)
I would never have tried them except I was interested in price Vs performance...Compared to jupiter HT in this part of this circuit..Well yes different..for the price you have got to try these
Switched on Jessie J and goose bumps..LOL
So as it stands now for a laugh orange drop to Op tubes and as above..LOL
The saga continues...
M. Gregg
Old 28th January 2012, 04:08 PM   #724
Just a thought
Orange drop are 716 not 715<<<there is a big difference!
M. Gregg
Old 28th January 2012, 05:57 PM   #725
Error,,
Post #723
LOL I thought I better say knowing how pedantic the forum can be,
I mean the Power Tx's are over rated not under rated for the job..
M. Gregg
Old 30th January 2012, 05:58 PM   #726
Alastair,
You are correct with the nipple distortion..I have found that a low value of resistor on the grid of the PI is an issue. I now have 120K in this postion.
The effect sounds like the speakers are out of sink with each other..a bit like some else is singing along very quietly...quite a strange effect..
This also gives reduced power available due to the overriding distortion effecting the OP at higher powers.. So your right again...LOL
Just for fun the 1813 vishay caps (output to 6C33C) give a tighter base with the Obbligatos in the interstage position..may not be of interest..
M. Gregg
Old 31st January 2012, 12:52 PM   #727
Final comment on the caps,
All now as in post #723,
0.47uF 400V 716 orange drop OP to 6C33C and 0.22uF 630V Obbligato gold in the interstage cap position. (Works well with most sources)..
Cheap and works very well...(good low level detail)
With the change of PI grid resistor (metal film) is 120K..
No comments on the high end stuff..each to his own...
I guess its time to look at other things..LOL
M. Gregg
Old 31st January 2012, 05:31 PM   #728
Alastair E's Avatar
Sounds like you been having lots of fun!
Yes--That resistor helps with distortion at the high signal-levels, to help even more, a greater supply volts to the PI would be good, so the 'headroom' before clip/dist would be higher...
A different valve for the PI would be another option....
Das Beste Oder Nichts
Old 31st January 2012, 09:13 PM   #729
Originally Posted by M Gregg View Post
OK just an update,
M. Gregg
Its good to play with different type of capacitors , but not overdo it , it will became "cheaty" , there is still many experiments to do , to "improve " the sound of thge amp .
Old 1st February 2012, 01:05 PM   #730
I think,
If I was going to mod then in order of preference they would be:
Increase the B+ on the PI to 500V
Use Fet driver direct onto 6C33C tube grid
Change PI to 6V6 or 6L6
Taking in to account that the amp is built then these are questionable..
But...
M. Gregg
FS: Vacuum Tube Monoblock Power Amp Kit cuibono Swap Meet 13 7th May 2011 01:49 AM
Vacuum tube VCO Bitrex Tubes / Valves 1 15th March 2011 01:07 PM
HLLY MK III 3 Vacuum Tube Headphone Amplifier Pre Amp hllyelec Vendor's Bazaar 2 19th July 2009 06:54 AM
S3E Vacuum Tube angsuman Tubes / Valves 12 15th March 2008 06:12 AM
DIY Vacuum tube amp turbo_h4 Tubes / Valves 2 1st July 2004 02:48 AM
Copyright 1999-2017 diyAudio
