Vacuum Tube OTL power amp!!
Old 5th January 2012, 09:21 PM   #711
M Gregg is offline M Gregg  England
Originally Posted by flatheadmurre View Post
You´re only benefitting from the constant voltage when running it hard.
At low OP it should perform the same as katodbias.
I agree ,,if the voltage across the cap was to remain the same ie change with number of heaters running... 40v (one heater) 46V(two heaters)<<<resistor bias
If the voltage across the cap/resistor remains the same voltage more current must be flowing through the FET to reduce the voltage across the resistor?
This must effect the bias at idle?
M. Gregg
Old 5th January 2012, 09:27 PM   #712
flatheadmurre is offline flatheadmurre  Sweden
When running amp at low power you´re in class A.
When running it harder towards AB the mozener keeps bias from drifting giving less distorsion.
Old 5th January 2012, 09:31 PM   #713
This does does show..the amp is cleaner much futher up the volume scale..
Its a bit to far for my speakers .....
M. Gregg
Old 5th January 2012, 09:40 PM   #714
What are the ratings of the speakers ?
You´re only putting out ~10W.
Old 5th January 2012, 09:52 PM   #715
I think they are 20W..I know they should be OK...Its just the bass really moves the cones..
Not sure if these are exactly the same generation but very close ..
http://www.madisoundspeakerstore.com...-4-full-range/
M. Gregg
Old 5th January 2012, 10:05 PM   #716
Yes it´s a big difference in current available for driving the bass.
A transformer based amp has less in the lower region.
I expect my new PSU to give even better result.
Old 5th January 2012, 10:44 PM   #717
Alastair E is offline Alastair E  Wales
Alastair E's Avatar
Worth remembering the Impedance presented to the amp by the speaker at or near its freq of resonance, --for the Alpair 7 70 Hz, its many times the DC or quoted nominal impedance...
For the Alpair, its approaching something like 50 ohms at 70 Hz, therefore an easier load for the amp and more effective power can be realised.....
Das Beste Oder Nichts
Old 6th January 2012, 07:48 AM   #718
The only trouble is..
When you power them for the first time you can only have them at transistor radio volumes (I have a feeling you would damage them if you try to push them their so tight) and they produce what sounds like "0" bass...Then a very slow break in period over 6 Months..LOL
Then your stuffing polyfluff in the vent to reduce the bass...cuz its so loud..LOL
M. Gregg
Old 17th January 2012, 09:42 AM   #719
florindo is offline florindo  Italy
Yes i see it
Old 28th January 2012, 02:47 PM   #720
OK just an update,
The toroids now have cork pads under the rubber pads made from cork tiles..
Result reduced Tx noise (mechanical)..
(Tx under rated no heat issue)
The 0.22 interstage cap was changed just for a laugh to Obbligato 630V <<(seem to like violin don't know why)
I would never have tried them except I was interested in price Vs performance...Compared to jupiter HT in this part of this circuit..Well yes different..for the price you have got to try these
Switched on Jessie J and goose bumps..LOL
So as it stands now for a laugh orange drop to Op tubes and as above..LOL
The saga continues...
M. Gregg
Vacuum Tube OTL power amp!!Hide this!Advertise here!
FS: Vacuum Tube Monoblock Power Amp Kit cuibono Swap Meet 13 7th May 2011 12:49 AM
Vacuum tube VCO Bitrex Instruments and Amps 1 15th March 2011 12:07 PM
HLLY MK III 3 Vacuum Tube Headphone Amplifier Pre Amp hllyelec Vendor's Bazaar 2 19th July 2009 05:54 AM
S3E Vacuum Tube angsuman Tubes / Valves 12 15th March 2008 05:12 AM
DIY Vacuum tube amp turbo_h4 Tubes / Valves 2 1st July 2004 01:48 AM
