Vacuum Tube OTL power amp!!
Old 2nd January 2012, 01:40 PM   #701
Dimitris AR is offline Dimitris AR  Greece
Hi Gregg ,very nice amp build , congratulations !! .
Old 5th January 2012, 06:16 PM   #702
M Gregg is offline M Gregg  England
Just for interest,
Mozeners fitted started burn in.... A couple of orange drop 716 in the 1st to second stage coupling just for a test..
M. Gregg
Old 5th January 2012, 06:21 PM   #703
flatheadmurre is offline flatheadmurre  Sweden
What voltage and current did you get ?
How even is it wthout the trimmers ?
Old 5th January 2012, 06:30 PM   #704
I haven't measured it yet just listening...I have only just completed the mod
So I will measure it as soon as I get a chance (work getting in the way)..
M. Gregg
Old 5th January 2012, 06:46 PM   #705
How´s first impression ?
Old 5th January 2012, 07:27 PM   #706
It's very loud..
With two heaters on it's a bit much to stand in front of the speakers...I am also concerned about damage to the speakers the cones are being driven quite hard... at these volumes...YMMV
sound is clear and powerfull...its a bit early to tell yet it needs to burn in..
I'm only using the mozener as a clamp....so the heat will be less spread across the resistor and FET.. cap still in place at the moment...
I don't want to use the trim pot its another pain in the ....like fixed bias..
...it's almost cheating....so I might change a few resistors to get it close..LOL
M. Gregg
Old 5th January 2012, 07:34 PM   #707
Its interesting,
I think I prefer the sound of one heater ....wonder why ...sound is smoother and perhaps warmer..triode sound comes to mind...
Anyway I will do some tests when I get chance..
M. Gregg
Old 5th January 2012, 07:39 PM   #708
Thinking,
I have the zener voltage set so with one heater its not in conduction at idle..
With two heaters its in conduction at idle by a couple of volts..
Perhaps that is the difference..
M. Gregg
Old 5th January 2012, 08:47 PM   #709
The mozener,
Does clamp the cap voltage and prevents the increase of cap voltage when two heaters are switched in... << just an observation
The only thing I can think of is my speakers must drive well with just a few watts.. I have no other explanation...
M. Gregg
Old 5th January 2012, 09:04 PM   #710
You´re only benefitting from the constant voltage when running it hard.
At low OP it should perform the same as katodbias.
Vacuum Tube OTL power amp!!Hide this!Advertise here!
FS: Vacuum Tube Monoblock Power Amp Kit cuibono Swap Meet 13 7th May 2011 12:49 AM
Vacuum tube VCO Bitrex Instruments and Amps 1 15th March 2011 12:07 PM
HLLY MK III 3 Vacuum Tube Headphone Amplifier Pre Amp hllyelec Vendor's Bazaar 2 19th July 2009 05:54 AM
S3E Vacuum Tube angsuman Tubes / Valves 12 15th March 2008 05:12 AM
DIY Vacuum tube amp turbo_h4 Tubes / Valves 2 1st July 2004 01:48 AM
