Vacuum Tube OTL power amp!!
Old 29th December 2011, 11:09 PM   #681
flatheadmurre is offline flatheadmurre  Sweden
Im back to katodbias but with a mosfet assisted zener for the moment.
Gives me ~10w no adjusting needed.
Amp was giving best THD at 45w disipation but now im down to 30w not wanting to make bigger hole in the ozonlayer .
Old 29th December 2011, 11:39 PM   #682
Dimitris AR is offline Dimitris AR  Greece
Nice , 10 watts is quite good , you are runing the 6C33c in the half of its maximum power , something similar with me, I am runing the PL36 at 5.5 W ( each one ) when max power dissip. is 13W . I suggest to use the 6SN7 as PI / driver and parallel the two sections , this will give you a good driver for your amp .
Old 29th December 2011, 11:58 PM   #683
I agree on the 6sn7 for PI its on the to do list.
I modified my PSU added a couple of small chokes and some more C.
I Have 7 huge 6800uF RIFA Elyts i want to use but they just dont fit the chassi.
I think its time to assemble and enjoy.
And start planning for the next one
Old 30th December 2011, 12:06 AM   #684
How much capacitance for each rail now ? . And what is the next plan ?
Old 30th December 2011, 12:26 AM   #685
7x680uF+680 between + and -
I have a box of E130L another of PL36 and a 9pin surprice.
Old 30th December 2011, 12:33 AM   #686
E130L I think its similar to EL136 , it would be so nice in an new OTL amp !! .
Old 30th December 2011, 12:39 AM   #687
Old 30th December 2011, 12:47 AM   #688
The 9 pin has 10w disipation and is made for telephonerepeaters driving long copper cables.
Have a box to fry so must be tested.
Old 30th December 2011, 10:43 PM   #689
I guess you are talking about the 6C19P or another one similar .
Old 30th December 2011, 10:57 PM   #690
Something LM Ericsson made for swedish telecom company.
Vacuum Tube OTL power amp!!Hide this!Advertise here!
FS: Vacuum Tube Monoblock Power Amp Kit cuibono Swap Meet 13 7th May 2011 12:49 AM
Vacuum tube VCO Bitrex Instruments and Amps 1 15th March 2011 12:07 PM
HLLY MK III 3 Vacuum Tube Headphone Amplifier Pre Amp hllyelec Vendor's Bazaar 2 19th July 2009 05:54 AM
S3E Vacuum Tube angsuman Tubes / Valves 12 15th March 2008 05:12 AM
DIY Vacuum tube amp turbo_h4 Tubes / Valves 2 1st July 2004 01:48 AM
