Vacuum Tube OTL power amp!! - Page 63 - diyAudio
Old 20th December 2011, 08:05 PM   #621
Resistor failure probably to low voltage rating.
Its starting to come alive, sounds better for every minute.
Cant turn it all the way up starts distorting badly at 75%.
Ill let run at 50% for a burnin period before starting to measure which stage is doing what.
Have start figuring out a way to trick it into playing a little louder .
Old 20th December 2011, 08:28 PM   #622
M Gregg is offline M Gregg  England
Great!
Old 20th December 2011, 09:01 PM   #623
Is it sill running??
M. Gregg
Old 20th December 2011, 09:06 PM   #624
Loud and its way past bed time
Details are coming out think the russians need some time.
Old 20th December 2011, 09:07 PM   #625
But it's only 1.5W...LOL
M. Gregg
Old 20th December 2011, 09:17 PM   #626
The 6C33C's need about a month to burn in..
They start to sing after about 30 mins..
Do you have the option to run on one heater?
(I would give it a while before you switch to one)
M. Gregg
Old 20th December 2011, 09:32 PM   #627
I have a switch installed.
Will run it for some time before messing with it.
First time since start that i feel like im ahead of it.
Old 20th December 2011, 09:34 PM   #628
Thats great!
I'm really looking forward to your progress..
M. Gregg
Old 21st December 2011, 05:08 PM   #629
Just a few tests,
1st stage CCS now has CC 330 Ohm + Ferrite bead.
2nd stage CCS still 270 Ohm + Ferrite bead.
The bead is insulated from the resistor leg (on the gate side) with PTFE sleeve.
No instability and highs are more open..
New 716 orange drop in the PI output to 6C33C's just for a test...burn in taking place...curiosity!
Looking at cathode CVS across existing resistors....
M. Gregg
Old 21st December 2011, 05:22 PM   #630
Measurements tells that bias voltage in the output stage must be stabilized.
The amp delivers about 10watts before it drifts due to lack of stability.
It drifts of into classB land when run hard.
A zener referenced fet will do the job as constant bias voltage i hope.
Another way is to run it hotter someone experienced please shout if im on the wrong track.
FS: Vacuum Tube Monoblock Power Amp Kit cuibono Swap Meet 13 7th May 2011 01:49 AM
Vacuum tube VCO Bitrex Tubes / Valves 1 15th March 2011 01:07 PM
HLLY MK III 3 Vacuum Tube Headphone Amplifier Pre Amp hllyelec Vendor's Bazaar 2 19th July 2009 06:54 AM
S3E Vacuum Tube angsuman Tubes / Valves 12 15th March 2008 06:12 AM
DIY Vacuum tube amp turbo_h4 Tubes / Valves 2 1st July 2004 02:48 AM
Copyright 1999-2017 diyAudio
