Vacuum Tube OTL power amp!!
Old 19th December 2011, 04:28 PM   #601
M Gregg is offline M Gregg  England
It could be the divider for the DC coupling
If this was to flash over then it would stuff the tube...
M. Gregg
Old 19th December 2011, 04:46 PM   #602
flatheadmurre is offline flatheadmurre  Sweden
Iīve split it and soldered wires so i can run it disassembled.
Didnīt have a neon so stuck in a zener instead.
Checked the tubes one 6j5 dead one bad.
Didnīt check them since they were NIB NOS Brimar just stuck them in.
Time for a new trip to storage and some non "drive by engineering" check recheck doublecheck then fireup.
Old 19th December 2011, 05:04 PM   #603
A standard diode would be better 1N4007 has been used in the past..
1n4148..etc
M. Gregg
Old 19th December 2011, 05:06 PM   #604
Just for interest..
I wonder if this could be your oscillator conduction in both directions with a zener?
File Type: png Protection Diode grid to cathode protection.png (10.1 KB, 287 views)
Old 19th December 2011, 06:25 PM   #605
Express trip to storage.
Soon to be tested !
Old 19th December 2011, 08:00 PM   #606
Soon to be tested !
I guess these have a series resistor 110v...no resistor required just straight from grid to cathode.
They will come on for about 5-10 seconds then as the tubes warm up they go off...
M. Gregg
Old 20th December 2011, 10:32 AM   #607
Just for reflection,
I have found that I tend to run the amp many hours at a time..
I don't even think about the tube offset or the bias... (never enters my thoughts)
I never even think of it as OTL...
Just switch on and play..I find I tend to head straight to the amp and power on as soon as I come home.
It’s on mainly on one heater for 4-6 hrs a day..Most days..
Strange....most amps I have bought or built tend to get switched off after a time..not this one..when I go to turn it off I don't want to..normally under pressure for someone to go and do something..YMMV
M. Gregg
Old 20th December 2011, 02:23 PM   #608
LOL,
Back to reality...are we their yet!!
M. Gregg
Old 20th December 2011, 04:09 PM   #609
My stash of 6j5Gs are out only ones i found is "no glows"
No nice CC so far but iīll dig around a bit more.
Neons didnīt make any magic.
That pesty oscillation is probably related to the cheapskate resistors.
Old 20th December 2011, 04:23 PM   #610
I was realy hoping you were going to crack it....
I hope you get there...
M. Gregg
Vacuum Tube OTL power amp!!Hide this!Advertise here!
FS: Vacuum Tube Monoblock Power Amp Kit cuibono Swap Meet 13 7th May 2011 12:49 AM
Vacuum tube VCO Bitrex Instruments and Amps 1 15th March 2011 12:07 PM
HLLY MK III 3 Vacuum Tube Headphone Amplifier Pre Amp hllyelec Vendor's Bazaar 2 19th July 2009 05:54 AM
S3E Vacuum Tube angsuman Tubes / Valves 12 15th March 2008 05:12 AM
DIY Vacuum tube amp turbo_h4 Tubes / Valves 2 1st July 2004 01:48 AM
