Vacuum Tube OTL power amp!! - Page 6 - diyAudio
Old 24th May 2011, 03:19 PM   #51
M Gregg is offline M Gregg  England
Originally Posted by Alastair E View Post
Output impedance will increase....
'Reflected Imp'. normally refers to Transformer coupling...
Miller shouldnt be an issue, the drive signal is strong enough anyway...
Yes sorry (No Tx) wrong terminology,
I was thinking about the change in output impedance and power transfer to the 8 Ohm / 6 Ohm speaker.
M. Gregg
Old 24th May 2011, 03:52 PM   #52
Ok,
I'll start collecting parts and think about chassis design.
Should be interesting!
M. Gregg
Old 24th May 2011, 06:46 PM   #53
Brouilly's Avatar
Would be very interested in following your project M. Gregg, hope you document it here.
Cheers
Broke solderer with delusions of grandeur
Old 24th May 2011, 07:52 PM   #54
Alastair E's Avatar
M. Gregg
If you want to reduce the effects of single-cathode operation and lower the O/P impedance, a nominal amount of global-feedback can be applied into the grid of the first stage, a la Tim-Mellow OTL.
Use a 33K in series with the vol-pot wiper to G1, and a 470K from O/P to the G1 of the first-gain stage.....
Ive tried this, and although it does reduce the overall gain somewhat, it will minimise the effects of a higher o/p impedance using 6C41C or single-cathode 6C33C operation at lower powers
Try it with, and without GNFB, Vary the amount even--See which you personally like the best, Thats the great thing about DIY-Audio....
Personally, I think I prefer without, but I'm giving it a few days listening now with to decide....
Old 24th May 2011, 09:55 PM   #55
Is this correct position for the 33K?
Or is it between the grid and the 470K?
M. Gregg
Old 24th May 2011, 10:31 PM   #56
Alastair E's Avatar
Aye, Thats it....
Old 24th May 2011, 11:19 PM   #57
Alastair E's Avatar
Here you go, Ive re-drawn the scheme, tidying it slightly and including the 22K omitted and the nfb loop....
--Just noticed, during cleanup, ive not put correct value for R15. This should be 4.7Meg, not 100K
Old 25th May 2011, 06:55 AM   #58
Thank's,
I notice the 120 - 120V Tx is not so easy to find.
Have you ever used Airlink Tx's
Transformer Manufacturer UK - Airlink Transformers - Home Page
Wondered if they HUMMMM like a wasps nest?
M. Gregg
Old 25th May 2011, 10:25 AM   #59
Alastair E's Avatar
A quick look, and Ive found this--
9639 : 300VA 230V 1 x 110V toroidal transformer
You would need 2, one for each 150V rail, but they will happily supply both channels...
Prob cheaper than using/getting made a custom jobbie...Being toroidal, noise/hum should be minimal...
--I'll look around for summit better anyway....
There's this one too, bit bigger and more expensive, but has 115-0-115V, so you'll only need the one...
-It seems to have a pretty good spec and shielding etc, looks like it was originally made for some fairly noise sensitive equipment rather than general use. Should be nice and quiet...
http://www.airlinktransformers.com/t...ransformer.asp
Old 25th May 2011, 04:42 PM   #60
Any ideas,
How much current drawn on each channel on the 350VDC supply?
M. Gregg
FS: Vacuum Tube Monoblock Power Amp Kit cuibono Swap Meet 13 7th May 2011 12:49 AM
Vacuum tube VCO Bitrex Instruments and Amps 1 15th March 2011 12:07 PM
HLLY MK III 3 Vacuum Tube Headphone Amplifier Pre Amp hllyelec Vendor's Bazaar 2 19th July 2009 05:54 AM
S3E Vacuum Tube angsuman Tubes / Valves 12 15th March 2008 05:12 AM
DIY Vacuum tube amp turbo_h4 Tubes / Valves 2 1st July 2004 01:48 AM
Copyright 1999-2017 diyAudio
