Old 3rd December 2011, 06:40 PM   #481
M Gregg is offline M Gregg  United Kingdom
M Gregg's Avatar
Ok here is half 6c33c..
using True RTA ,,not set up just as a signal gen..at 1Khz
All readings are with a X10 probe so you have to multiply...
Obviously it gets more distorted as you increase input..
The first one is 5.5V
Second is at 11V
What is the sound of one hand clapping?
Old 3rd December 2011, 06:47 PM   #482
M Gregg's Avatar
Full 6c33c..
At 8/9/10/11/12V...I did manage 13V however the 1.6A T fuse blew..so no picks ...didn't want to try it again..drawing 1.7A
Again X10 probe so you have to multiply..
M. Gregg
Old 3rd December 2011, 06:51 PM   #483
M Gregg's Avatar
low distortion on half 6c33c
Is app 3.78w
flat out is app 15w
flat out is 15watt
Full 6c33c..
Low dist 8watt
flat out is 21Watt
M. Gregg
Old 3rd December 2011, 06:59 PM   #484
M Gregg's Avatar
Tried to do 10khz square wave and 25k..
however the True RTA makes a right mess of it looks like triangular..
So I will have a look at it with a sig gen..
M. Gregg
Old 3rd December 2011, 07:17 PM   #485
M Gregg's Avatar
10khz..square wave.
Old 3rd December 2011, 07:25 PM   #486
M Gregg's Avatar
20khz square wave..
Could do with a tweek to sharpen the edges..
Could be the coupling caps to the 6c33c's..looking to change them,,
M. Gregg
Old 3rd December 2011, 07:47 PM   #487
M Gregg's Avatar
Half 6c33c 10khz square wave..
The scope leads arn't the best my others got squashed in the loft...
Old 3rd December 2011, 07:56 PM   #488
M Gregg's Avatar
Half 6c33c at 20hz
just for fun..
Old 3rd December 2011, 07:58 PM   #489
M Gregg's Avatar
Here it is..
Old 3rd December 2011, 08:33 PM   #490
Alastair E's Avatar
Well, Thats all pretty interesting!
I really should get my scope out and do some tests too. It would be interesting to see where the onset of distortion is actually happening above 8W, whether in the driver or the O/P stage...
--Have to open the FB loop to do that though, and alter I/P level accordingly...
To sharpen up the square-waves, it may be worth dropping the value of the PI grid-coupling resistor to 100K, (or just link it out) in view of what a previous poster mentioned concerning the Miller capacitance of that stage....
Worth trying anyway, see if it makes a difference...
Das Beste Oder Nichts
FS: Vacuum Tube Monoblock Power Amp Kit cuibono Swap Meet 13 7th May 2011 12:49 AM
Vacuum tube VCO Bitrex Tubes / Valves 1 15th March 2011 12:07 PM
HLLY MK III 3 Vacuum Tube Headphone Amplifier Pre Amp hllyelec Vendor's Bazaar 2 19th July 2009 05:54 AM
S3E Vacuum Tube angsuman Tubes / Valves 12 15th March 2008 05:12 AM
DIY Vacuum tube amp turbo_h4 Tubes / Valves 2 1st July 2004 01:48 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
