Vacuum Tube OTL power amp!!
Old 21st May 2011, 09:03 AM   #31
M Gregg is offline M Gregg  England
Alastair another quick question,
What is the distance you have between the 6C33B's / distance to any Tx.
DO you use series heaters for each tube and parallel the two in the left and right or series all heaters in left channel / same in the right?
Each in series would give approx 4A per tube? 8A parallel.
I have seen someone mention neon protection for the speakers, do you have any thoughts on this?
M. Gregg
Old 21st May 2011, 09:56 AM   #32
Alastair E is offline Alastair E  Wales
Alastair E's Avatar
All 6C33 heaters series-wired, supplied by 25V 5A, x2 Tx, a two-secondary toroid supplying them.... The three Tx are mounted down the centre of chassis, on top of case, I had to run a strut under them, with a 'leg' down to the bottom to stop the cheapo case sagging!
--As I said, It aint pretty, Hence no pics! but its a reasonably safe and usable machine
There's about 2.5" between any 6C33 and any other tube/item. There's spacers under the sockets leaving a small gap between them and chassis, there's also a PC fan in the case, running from rectified 6.3V, running under the 6C33 sockets. Its very quiet, only running at half-speed or so, the air can pass through the gap by the sockets up the sides of the valves....
--Ive mounted the caps under the chassis, inside the 'box' feeling that these should be kept as cool as is possible.
Heat doesn't seem to be a problem, although I certainly wouldnt grab a tube after an hours playing!
Not heard of the 'neon' thing, but wouldnt have thought a neon would protect a speaker. The 1.5A a/s fuse is sufficient IMO. Ive never had it blow--Yet, and Ive done some daft stuff with it....
Old 21st May 2011, 04:17 PM   #33
Another question,
Where did you get your "sockets" -bases for the 6C33b's?
M. Gregg
Old 21st May 2011, 09:10 PM   #34
Alastair E's Avatar
Ive used a number of different suppliers--mainly ebay--but also got some excellent ones -british made- from a radio-rally a year or so ago...
Stay away from Chinese sockets appears to be good advice given on these Forums....
Its important to use very heavy wires to connect the heater-conns with to act as heat-sinks, as these give the most trouble with contact--allegedly....
--I'm using some '15A Rubber-Covered' cable I got from a local Motor Re-winders....
Old 22nd May 2011, 10:17 AM   #35
Few more questions..LOL
Did you twist the heaters cables?
Next question,
U1 is 6sn7 "strapped" I assume you mean using both sides of the 6sn7 as one triode. ie. Anode to Anode, grid to grid cathode to cathode?
Not one half on each channel?
One more question,
What are the hottest components in the circuit "not the tubes"
R9, 10, and 14 come to mind. Any special precautions you have found with position?
M. Gregg
Old 22nd May 2011, 10:48 AM   #36
Alastair E's Avatar
Yes, the heater runs are a twisted pair...
The 6SL7 is connected A-A, G-G, C-C,--ie, Paralleled out...
--Its a 6SL7, not SN7....
R9, R10 are the highest dissipation, I used standard 17W WW resistors.
R14 from speaker out to earth doesnt really get warm even.
The Phase-Splitter resistors need to be 2W at least as these get pretty hot, Nothing much else except the MOSFET gets warm really, and that is mounted on the case which is fine...
--Just noticed, Ive omitted a resistor in the schematic---
Need a 22K from top end of R3 to earth, (Joint between R3 and R16 to earth).....
Old 22nd May 2011, 01:21 PM   #37
LOL,
Like this?
Do you start the heaters first then time in HT or all togeather?
6SL7 --ECC83 did you try an 83 or do you prefer the octal?
Just for interest the neon circuit!
http://www.cincocoronas.com/nysva/im...tl/25w_otl.pdf
Also how do they get round the heat from the 6c33 tubes, look very close to me?
M. Gregg
Old 22nd May 2011, 03:26 PM   #38
Alastair E's Avatar
Yup--Thats correct on the resistor placement...
No, +B and heaters all on from stone-cold....
Never had any issues with any amp Ive made this way.
Old 22nd May 2011, 05:22 PM   #39
Any ideas,
what s the difference between 6c33b and 6c33c?
Is the valve base any different?
M. Gregg
Old 22nd May 2011, 05:41 PM   #40
Alastair E's Avatar
Well,--
They are all 6C33C tubes.....
The 6C33C-B allegedly are more strictly made and tested versions but for all practical purposes and our use of 'em they are completely interchangeable (Read, Identical) with each other....
I have both versions. The only valve I ever had fail some years ago (because I hadnt burned it in properly...) was the alleged 'better tested' 6C33C-B part.
--Personally, I just think they tested a number from various batches and shoved the suffix 'B' on some, that had been subjected to more stringent testing.
So, IMO--It makes Zero difference whether its a 6C33C or a 6C33C-B valve....
--Apparently, there's even a 6C33C-B.EV type out there, But Ive never seen any--Doubt they would be much 'better' than a plain one to be honest!
If buying some, and if possible, Go for 'early month' numbers--apparently late 'month-numbers' were rushed through to make sure quotas were kept for that factory, Whether this is true or not, I have no idea....
Also, for this circuit, Dont discount the 6C41C to use as a low-power O/P version. (They are dirt-cheap too) They'll give around 9-11W and sound really as good as the '33 but need a Good Burn-In first, just like the '33 Have the advantage too of much less heat/power 'waste'
My choice of 'Octal' over 9-pin is just personal, I prefer the larger style and never really liked the 'ECC' series dual-triode valves...
Whatever output bottles you end up using, Burn Them In WELL before running 'em in an amp--Any Amp--Loads on this forum about how to and why....
Not sure of the 'Neon' trick--Still thinking of that one!
Vacuum Tube OTL power amp!!Hide this!Advertise here!
FS: Vacuum Tube Monoblock Power Amp Kit cuibono Swap Meet 13 7th May 2011 12:49 AM
Vacuum tube VCO Bitrex Instruments and Amps 1 15th March 2011 12:07 PM
HLLY MK III 3 Vacuum Tube Headphone Amplifier Pre Amp hllyelec Vendor's Bazaar 2 19th July 2009 05:54 AM
S3E Vacuum Tube angsuman Tubes / Valves 12 15th March 2008 05:12 AM
DIY Vacuum tube amp turbo_h4 Tubes / Valves 2 1st July 2004 01:48 AM
