Vacuum Tube OTL power amp!!
Old 20th May 2011, 07:30 PM   #21
M Gregg is offline M Gregg  England
What chassis size have you used?
M. Gregg
Old 20th May 2011, 07:31 PM   #22
Alastair E is offline Alastair E  Wales
Alastair E's Avatar
Its a 19" Rack box, Nothing special or pretty....
Old 20th May 2011, 07:37 PM   #23
So the PSU is Bi-polar + / - 150vDC, and 350vdc.
ss rectifiers?
What transformer have you used, current rating / voltage -make...LOL
Photo?
Sounds like an interesting project.
It's OK if the PSU is secret it can make or break an amp!
M. Gregg
Old 20th May 2011, 07:54 PM   #24
Alastair E's Avatar
PSU is completely standard. a SS Bridge-rec, after a large toroid I had floating round, I think it was an Isolating transformer...
I do have large 'RIFA' screw-term 3300uF 200V leccy-litics in each 150v rail, de-coupled by a couple of 10uF plastic caps...
The 350V supply is from a separate 'Maplin' mains Tx with CLC filtering....
Old 20th May 2011, 09:07 PM   #25
Thank's Alastair,
I may take this forward just for fun.
Is the SS rectifier just a standard bridge / or Hex ect?
Any snubbing used?
I guess no regulation?
With CLC filtering any Ideas on value of L you have used?
M. Gregg
Old 20th May 2011, 09:14 PM   #26
Alastair E's Avatar
Yup--standard ss bridge, no 'snubbing' and no regulation
The choke on the 350V line is 10H and 100uF caps, and SS rec.....
Old 20th May 2011, 09:16 PM   #27
DouglasSelf is offline DouglasSelf  United Kingdom
DouglasSelf's Avatar
You will find some old Wireless World articles on OTL valve amplifiers here:
The Wireless World Archive
Douglas Self
Old 20th May 2011, 09:17 PM   #28
Thank's again.
M. Gregg
Old 20th May 2011, 09:38 PM   #29
woody is offline woody
Any chance of a pc board for the amp?
Old 20th May 2011, 09:47 PM   #30
Alastair E's Avatar
Of which...?
Mine..?
Personally, I wouldnt bother with PCB's --especially if you're using 6C33C tubes--WAY too hot for 'em!
Nah, its all p2p wiring, no PCB for mine...
Vacuum Tube OTL power amp!!Hide this!Advertise here!
FS: Vacuum Tube Monoblock Power Amp Kit cuibono Swap Meet 13 7th May 2011 01:49 AM
Vacuum tube VCO Bitrex Instruments and Amps 1 15th March 2011 01:07 PM
HLLY MK III 3 Vacuum Tube Headphone Amplifier Pre Amp hllyelec Vendor's Bazaar 2 19th July 2009 06:54 AM
S3E Vacuum Tube angsuman Tubes / Valves 12 15th March 2008 06:12 AM
DIY Vacuum tube amp turbo_h4 Tubes / Valves 2 1st July 2004 02:48 AM
