Old 20th September 2011, 02:42 PM   #161
gkn202 is offline gkn202  Luxembourg
Originally Posted by Alastair E View Post
Hmm....
That aint much use --Without a Schematic!
All I get is a page of meanigless numbers and another page asking what program it needs to open it!
At least mine WORKS in the real world, with real tubes! Ive never put much faith in simulations, Especially with Tube circuits, Sims never seem to hold up!
Any chance of a scheme we can look at??
hmmm...
just the schema, here it is... I've also posted a ZIP with the model and its library.
Gary
Old 2nd October 2011, 05:29 PM   #162
M Gregg is offline M Gregg  United Kingdom
M Gregg's Avatar
Just some more progress,
Just for fun.
Driver/preamp board.
I wanted to compress it into a small area away from the 6c33c's.
So point to point wiring.
Just connections for the IRF710 to do.
Feedback is via PTFE home made screened cables.
Bias supply cap is Rubycon HV.
Coupling cap is Jupiter, Amtranz.
Takman resistors.
Heaters should be DC for the pre/ 6SN7's if all goes well!
and AC for the 6SL7.
Heater cables run across the back of the board to shield them from the pre circuits.
The board only provides screen no signal transfer. star Gnd.
Still on going, lots to do!
M. Gregg
What is the sound of one hand clapping?
Old 2nd October 2011, 06:05 PM   #163
M Gregg's Avatar
Regards the 6SL7,
Neon protection for the DC coupled stage.(grid cathode) has been fitted!
Just for interest the top plate shields the tubes from the Heater cables.
Alastair,
What voltage do you have on the anode of the driver tube?
(6SL7) in my circuit. So I can check the bias point, thank's.
M. Gregg
Old 2nd October 2011, 08:17 PM   #164
Alastair E's Avatar
I have about 120V on the anode, and a little less on the grid of the phase-splitter...
Sounds like you're nearly there!
Das Beste Oder Nichts
Old 2nd October 2011, 08:33 PM   #165
M Gregg's Avatar
Thank's,
I still have to complete the 6c33c wiring...
Also mount the FETS. A bit busy at work at the moment.
Its getting there.LOL
M. Gregg
Old 3rd October 2011, 09:09 PM   #166
M Gregg's Avatar
Just more progress,
Driver/ pre board completed.
M. Gregg
Old 5th October 2011, 08:33 AM   #167
M Gregg's Avatar
Post 162#
Error - S's & N's....late night...lol
Should say DC heaters for the 6SL7's and AC for the 6SN7.
Markings are wrong on pic 2 should have 2x 6SL7 and 1X 6SN7.
Now corrected
Wiring is correct to schematic. <<< accepting numbers for pin out should be 6SL series tube.
Back on track I guess...
M. Gregg
Old 5th October 2011, 11:30 AM   #168
M Gregg's Avatar
Just to show correctly.
M. Gregg
Old 6th October 2011, 01:56 PM   #169
M Gregg's Avatar
M. Gregg
Old 6th October 2011, 05:48 PM   #170
Very inspiring thread.
Getting the itch, must not start another build
A nice toroid for the input tubes HT and heater perhaps ?
Then it´s all toroid powered.
The amp is looking good !!
FS: Vacuum Tube Monoblock Power Amp Kit cuibono Swap Meet 13 7th May 2011 12:49 AM
Vacuum tube VCO Bitrex Tubes / Valves 1 15th March 2011 12:07 PM
HLLY MK III 3 Vacuum Tube Headphone Amplifier Pre Amp hllyelec Vendor's Bazaar 2 19th July 2009 05:54 AM
S3E Vacuum Tube angsuman Tubes / Valves 12 15th March 2008 05:12 AM
DIY Vacuum tube amp turbo_h4 Tubes / Valves 2 1st July 2004 01:48 AM
Copyright ©1999-2013 diyAudio
