diyAudio Sponsor
Old 19th May 2011, 05:24 PM   #11
tubelab.com's Avatar
Got any sweep tube suggestions? I'd like to keep it AB1 if possible.
At the power level your OPT's support any 12 pin compactron that can be used in the board will work. The board isn't designed for AB2, all power numbers quoted in the thread are in AB1. The thread has almost 1000 posts in it and tube numbers are scattered all through it. I am leaving for the Dayton hamfest (for more tubes of course) in a few minutes so I don't have time to search. I can remember the 6JS6, 6LR6, 6KN6, 6KD6, 6HF5, 6HJ5, and the 6HD5.
A lot of us that are building for 50 to 125 WPC have decided on the 6HJ5 since it can still be found for $5 and it doesn't have a plate cap. A minor circuit change is required for this tube. No board modifications are needed. I have run a couple dozen different tubes through the board and other users have run lots more. All seem to work well. Pete originally recommended the 6JN6, the 6JM6 or the 6GV5 all of these will work well up to 60 WPC. The 6GV5 was on several vendors $1 list until we grabbed them all.
If you are interested in building this board I would advise reading through most of the thread since Pete originally designed it (very conservatively) for 18 WPC. Many of us found different ways to crank it up. All are explained well, but the two transformer method works best for 80 WPC and up. 40 to 60 WPC can be done with only filter cap voltage changes.
I have also wired octal sockets into the board and used the 6DQ5, 6DQ6, 6BQ6, E130L, and a few others that I can't remember. The schematic is on Petes web site and at least one member has PTP wired his amp.
Too much power is almost enough! Turn it up till it explodes - then back up just a little.
Old 28th May 2011, 05:03 PM   #12
Jeb-D. is offline Jeb-D.  United States
Jeb-D.'s Avatar
Sweep tubes seems like the way to go. Thanks for the suggestion. I came across a russian tube 6P13S. The curves look promising for class AB and they can be had new-in-box for $2 a pop. I also found a power transformer from a fisher TA-600 which has taps on the secondary that would work perfect for a low voltage screen supply.
Petes board looks interesting, but is a little overly complex for my tastes. These tubes should only take 16V peak to drive to full power in this application. I'm just going to do a point-to-point common cathode - cathodyne - output type of arrangement.
Old 15th October 2011, 12:57 AM   #13
roline is offline roline  United States
roline's Avatar
Simple design, clarity and great sound stage. Output tubes can be found for $5 to $10 each. 40-60 watt transformers are perfect for it.
SO many tubes, SO little time!!!
Old 15th October 2011, 01:39 AM   #14
hidnplayr's Avatar
a Quad of PL36/EL36 in triode should do nicely.
Real tubes have top-caps
Old 15th October 2011, 05:11 AM   #15
Defiant is offline Defiant  United States
Defiant's Avatar
I'd run the 807's. Regular 6L6's, 5881's, or even 1625's would work too. Heck, 5.5k will work with many tubes even if it isn't what the data sheet specifies. A pair of EL34's would work fine and give an easy 40 watts with simple drive requirements.
Whatever you choose, use tube rectifiers Click the image to open in full size.
Old 15th October 2011, 11:15 AM   #16
Tony is offline Tony  Philippines
Tony's Avatar
Send a message via Yahoo to Tony Send a message via Skype™ to Tony
Originally Posted by Eli Duttman View Post
The Soviet surplus 6П3С-Е (6p3s-e) is a "meaty" member of the 6L6 clan. They are good sounding and not especially expensive. Jim McShane has properly culled and matched stock.
i built an amp with these 6P3S tubes using a dynaco A470 traffo with very good results......
snaken s-40w or sp-40w for pioneer sx-650 bolameon Swap Meet 1 3rd June 2011 07:07 PM
40W class A push pull amp with JJ 2A3-40w possible? 3nity Tubes / Valves 18 26th May 2010 11:05 PM
40w Class A Circuit kaybe Solid State 3 23rd February 2009 09:47 PM
Sanken S-40w Jorgitox Swap Meet 4 13th February 2009 10:00 AM
??10-40w a or single ended solid st amp? any suggestions? elviukai Solid State 4 8th May 2003 11:08 PM
Page generated in 0.09446 seconds (74.00% PHP - 26.00% MySQL) with 11 queries
